1968 Delmont
Where are you located? I'm located in Medford Oregon and have two that could be cores if yours is too rusted or damaged to fix. I wouldn't consider either of these to be good enough for a driver unless you were desperate to have something bolted to the car. I'm also dismantling one 1968 Delta 88 and one 1968 Delta Custom, both are two door hardtops and both have 455's. One car is complete, the other mostly complete. Let me know if your needing anything else. John
Shipping from Oregon to PA would be expensive, but the bumpers I have are off 1968's. One a Delta 88 the other a Delta Custom but I don't know for sure if the Delmont was the same, I thought it was in the 88 line. If you can't find a good one closer I can provide pictures of what these look like. Greyhound bus lines would probably be between $50-75 to ship, I would sell one for $50 to cover my time. John
If you wouldn't mind could you send the pictures to skielk@udel.edu so i can look at them and see if the bumper will work on the delmont. Thanks
TECH9TWISTA
April 2nd, 2007 06:51 PM
