1968 real 442 passenger fender not cutlass wanted
Hi I'am restoring my 1968 442 4 speed car and need a passenger front fender
with the correct hinge holes and emblem holes
does anyone have one available
please let me know
Thank you
please let me know
Thank you
There are two different hole patterns for the 4-4-2 numbers on the fenders in '68 - one with the W36 stripe and one without the W36 stripe. As well, you'll be lucky to find one that was specifically drilled for the 4-4-2. Your chances will be better if you look for an F85/Cutlass/4-4-2 fender and amend the holes to fit your pattern. It opens the field quite a bit. The 2-bolt hinge holes are the same for all 3 models.
Randy C.
'68 4-4-2 convertible
'69 4-4-2 convertible
Randy C.
Thank you for the info also without the w36 stripe
I'll keep looking so far no luck on any 68 passenger fender
someone told me it was an early 68 because it does only have the 2 hinge holes for the hood
not the 5 like replacement or later
Thanks again
Iam going to see if I can get one at least with the 2 hinge holes fender and maybe drill for emblems and go from there
Thanks again
Hi
Thanks for the reply Iam in Washington state also
could I get some pictures of hinge area eyebrow molding area and of course rear brace lower heel area inside and out
and what price did you have in mind and go from there
please give me a call and send pictures to my phone 509-679-2604
I'am definitely interested I could probably pick up
just let me know
Thanks again
just let me know
Thanks again
