1967 Toronado Carburetor 7027131 wanted
Old Nov 13, 2024 | 08:11 AM
BSiegPaint's Avatar
Thanks everyone, I've found the part I needed
I need a good quality core 7027131 carb for my '67 Toro. I'll certainly consider a fresh rebuild if you have one. Not looking for show quality, but would like better than a barn find... Let me know what you have! Thanks
Old Nov 15, 2024 | 11:42 AM
deaddds's Avatar
Bob, this is on one of my parts cars. The tag isn’t there so can’t swear on the number but all the hook ups are there so I’m fairly certain it’s correct. Drop me a line if you want it.
Old Nov 15, 2024 | 12:11 PM
The Toro's did not take the 257 carb?
Old Nov 15, 2024 | 01:33 PM
BSiegPaint's Avatar
They did not. Depending on AC or not and California A.I.R. pump usage, they used a 7027130, 131, or 132. The biggest issue I have with mine currently is getting the choke rod to connect. The correct one is about an inch too long and it messes up the rest of the linkage geometry.
deadds, it looks like the carb you have there is a 7043200, which is for a '73 454 Chevelle. Not that far off, but the vacuum connections are different.
Old Nov 15, 2024 | 03:41 PM
I will look out for that number. I don't think I have one, although I have several 442 carbs for that year.
Old Nov 16, 2024 | 06:53 AM
ourkid2000's Avatar
What carb is on the car currently?
Old Nov 16, 2024 | 08:50 AM
BSiegPaint's Avatar
I have a 7027202 quadrajet that is listed for a '67 Camaro/Chevelle with a 350/300 automatic trans. It works, but it's missing a vacuum post on the front that I need, and the choke connections are wrong.
Here is a side shot of the divorced choke rod - you can see how badly it misses the hole in the armature where it should connect.
Old Nov 16, 2024 | 05:59 PM
Paladin31's Avatar
Carb
I have one that is also missing the stamped tag, but when I had it at Homecoming a few years ago was told it was a 66 or 67 toro carb
so, I would be happy to take as many pics as you want/need to get as much info as possible.
let me know if your still looking
Brett
Old Nov 17, 2024 | 07:39 AM
BSiegPaint's Avatar
Brett
Sent you a PM - not quite the correct throttle linkage for my application - thank you for reaching out
tds
Mar 3, 2014 12:00 PM
ydennekkram
Feb 14, 2014 01:51 AM
sherman8r
Dec 10, 2013 02:10 PM
SteveNatale
Mar 16, 2011 08:58 PM
