1967 Olds 88/98 425 exhaust crossover pipe
Looking for one of these. I'm done trying to wrestle with mine, as the pass side mating flange is half rotted away and the bottom of it is a bit crumpled in from an unknown past incident. Please no high-end new/restored showpieces as it will just be connected to a pair of dingy exhaust manifolds next to an oily engine cradle, just looking for low-priced "junk" out of somebody's garage, only qualifier is no rot or crush damage.
Year isn't important, if any other similar year pipes are identical to a '67 I'd gladly take one. Lemme know what you've got, and thanks!
Here's a link from ebay for a guy in Geneva, Ohio. I needed a crossover pipe to put a 350 in in one of my 1967 98's. I got a nice set of 330 1967 Delmont factory single exhaust manifolds from a board member. They are different from 1967 425 exhaust manifolds and a 425 crossover pipe would not fit. I got in touch with that fellow and told him I need just a crossover pipe for a 1967 Delmont 330. He made it up and a couple days later after breakfast with my retired buddies I drove the 50 miles up to Geneva and picked it up. I have the engine on a stand and I installed it with all new studs washers and barrel nuts. It was off a tad but I could start it and it fit but it was under some "stress." I "stress relieved" it with a torch and took it back off to see how it fits and now it right on. I have a used 425 crossover pipe. If you want PM me and I'll tell you how much I paid and or if you're interested in a used pipe. Later, Ken Look at this on eBay http://www.ebay.com/itm/182473738593
Since this thread has been resurrected, I'll note that the BBO crossover pipes used on the 65-70 cars have a larger diameter pipe and wider spacing between the bolts on the flange than do the SBO crossovers. If you still have multiples, John, you can compare them.
Last Fall I purchased 5 BIG Block OLDS Engines
One was a 1970 455 with Exhaust Man
AND Crossover too. I have that motor advertised FOR SALE with exhaust , so far has not sold.
Maybe I will sell the exhaust from it?? What is it worth $$ to you??
