1967 442 Associated Steering Wheel Parts
Old Nov 16, 2019 | 09:46 AM
6OLDS4427's Avatar
1967 442 Steering Wheel Parts. Am looking for the heavy spring that goes under the steering wheel on the shaft, the white plastic piece that makes the horn work, and the small spring that goes in the tall round area in the plastic piece that makes contact for the horn button. My car has a later factory wood wheel on it.
Thank You
Old Nov 16, 2019 | 10:07 AM
Thank You
The white plastic part is the cancel cam. These are available repro, as is the contact assembly that goes into the post on the cancel cam.
Old Nov 16, 2019 | 11:03 AM
6OLDS4427's Avatar
Thanks for the information. I will still need the heavy spring that goes under the steering wheel.
Old Nov 16, 2019 | 05:40 PM
rocketscientis's Avatar
67 horn related pieces in color
Just removed all that for someone with same wheel on his......he needs burgundy steerin wheel spoke inlays if anyone knows of any available...
Theres a good posability I hav what you need
Pls call or txt me at 989 721 9432
Would b intrested how you made th switch of wheels as I believe my friend is havin little adventure with his
Old Nov 16, 2019 | 07:20 PM
first442's Avatar
PM sent
Old Nov 18, 2019 | 07:18 PM
6OLDS4427's Avatar
I was in touch with someone before your response, and he may have what I need. I will get back to you if that is not the case. Thank you for your response.
Old Nov 25, 2019 | 11:09 AM
Wjeel swap
What all did u hav to do to succesfullt swap them steering wheels....hav exact same senario
DZee
Aug 11, 2019 03:57 PM
neatolds
Aug 23, 2015 08:36 AM
mid60soldsfan
Jan 31, 2015 02:48 PM
Joffroi
Mar 29, 2011 02:06 PM
JPDPG
Nov 9, 2007 07:27 PM
