1966-67 Toronado Front Cigar Lighter assembly
Old Nov 28, 2023 | 03:12 PM
BSiegPaint's Avatar
***EDIT*** 11/29/23 I found what I needed - thanks everyone
I need the inner and outer lighter assembly cylinder for a '66-'67 Toronado. I have the lighter element, I just need the housing and the attaching cylinder. The 66-67 should have a single post connection for the wiring harness on the bottom. Used or new is fine - functional is the desire. Let me know what you have!
I was able to save the outer attaching cylinder (left) but the inner cylinder (right) is beyond salvaging. That’s the piece I need - thanks!
Old Nov 28, 2023 | 07:01 PM
deaddds's Avatar
How many you need Bob?
Old Nov 28, 2023 | 07:05 PM
BSiegPaint's Avatar
Honestly, I need the one up front, and I'm missing a lighter assembly in the back, if you have both
Old Nov 29, 2023 | 07:30 AM
rocketraider's Avatar
Oldsdruid
I was gonna say yer FLAPS ought to have the lighter well. Then it occurred to me many new cars don't have lighters and all you might be able to find would be a 12v power outlet- which wouldn't work with a lighter if that's what you're trying to accomplish.
Think it was cfair who reworked all his lighter outlets to USB charging ports?
Old Nov 29, 2023 | 07:44 AM
BSiegPaint's Avatar
The thought has certainly crossed my mind. The issue I have is determining how large the power insert needs to be, since there are so many varieties of lighters out there. I figured the easiest thing to do would be to get a working factory socket, then I could do something simple like add a plug in USB/charger insert. Since I have now figured out how to drop the ash tray without much trouble, I can add a more permanent power outlet at a later date.
Sep 16, 2022 12:12 PM
REO442
Mar 22, 2022 08:42 AM
sharkkk
Nov 8, 2021 06:17 AM
Gustav455
Dec 8, 2009 05:36 PM
