1965 ninety eight power window switches
Old Aug 22, 2013 | 11:27 AM
65oldsninetyeight's Avatar
Hey guys,
Looking for a drivers side window switch panel. I have a 1965 holiday sedan.
Old Aug 22, 2013 | 11:50 AM
m371961's Avatar
These can be carefully disassembled and cleaned, bending contacts etc. Somewhere on here is a thread that discribes this. I also found on mine it is best to go through and clean or replace circuit breaker and relay. I had trouble with intermittent operation of windows and power seat until I did this on mine. Could not find replacement switch.
Old Aug 22, 2013 | 11:58 AM
m371961's Avatar
This is for a Cutlass repair, but principle is the same.
https://classicoldsmobile.com/forums...-switches.html
I also had a lot of problem with the harness plug for these, but manage to repair it with JB weld.
Old Aug 22, 2013 | 01:02 PM
awesome.. thanks so much.. yea my harness plug was pretty much done for.. i soddered a wire to each pin with a quick connector. cut the crappy plug off and put the other end of the quick connect. nice connection now, just lots of wires.
Old Aug 22, 2013 | 01:39 PM
m371961's Avatar
Your welcome. I soldered the wires on the pass. side directly to the switch.
If you have trouble with the breaker or relay, I replaced mine with aftermarket new ones, had to change wiring slightly for replacement relay.
FYI, breaker is on firewall between brake booster and fenderwell, relay under left kick panel.
Lady72nRob71
Apr 2, 2024 06:55 PM
oldspackrat
Feb 17, 2011 05:32 AM
69convertible
Dec 7, 2008 02:03 PM
real442
Mar 18, 2008 04:35 AM
real442
Mar 8, 2008 07:03 PM
