1965 Full Size AC line needed
Old May 30th, 2023 | 07:36 PM
justintiime's Avatar
mmmm, starfires
For a 1965 Starfire/88 possibly others. I need this aluminum line with 90* bend that follows passenger fender and radiator support.
Old May 30th, 2023 | 07:40 PM
cfair's Avatar
Good on you for looking for a factory part, but am I wrong to think this is something you could make or have made for not too many $?
Isn’t is just a bent line with fittings and flares on the ends?
All for originality, but finding such a part new & functional would seem like a pretty tall order to me. Or maybe it’s a moment for me to learn.
Cheers
Chris
Old May 30th, 2023 | 07:45 PM
mmmm, starfires
Cheers
Chris
I found a bent and twisted line off another parts car. Literally the only one I have found. Brought it to a local shop where they were able to salvage the fittings off of it, but they are unable to bend a new tube without kinking it, so I'm kind of stuck unless I can find someone to bend me a proper line.
Old May 30th, 2023 | 09:12 PM
cfair's Avatar
I’m not that up on A/C lines, but I’ve bent a bunch of my own steel fuel & vacuum lines.
Unless the line must be aluminum for heat/cool or weird fittings, maybe get some stainless steel line of the right size/gauge, figure out the flare and reuse the fittings.
I freely admit my ignorance about A/C lines, but bending up steel lines can be learned in a weekend with enough practice materials & patience. I may have a post here somewhere about what I did for fuel and vacuum lines. It was fun to learn, I can’t recall if I documented it here.
One big tip is to model up the bends with a coat hanger or welding wire, take that to the bench, then use a quality tubing bender to create your new line. The other important tip is to put the fittings on _before_ you flare the ends. Or you’ll start again. Cuz the fittings won’t slip over the flares.
Hopefully not under-thinking it..
Chris
Ral
December 30th, 2021 04:09 AM
F-85 4-4-2
July 3rd, 2021 09:13 AM
schlitzguzzler1
June 5th, 2021 11:34 AM
REDJET
June 1st, 2015 07:36 PM
