1965 Delta/Dynamic Front Wheel Hub
Old Apr 20, 2016 | 12:42 PM
AtomicMyke's Avatar
Hey All, I'm Looking to see if anyone has a front wheel hub for my 65 for sale. If In/Near California even better! I can't find one nearby and I need if severely for my daily. Thanks!
Old Apr 20, 2016 | 01:54 PM
jcdynamic88's Avatar
i couldn't be further from cal but i have them if you can't find any.what is wrong with yours?i would need something to keep the parts car rolling.jc
Old Apr 20, 2016 | 01:56 PM
AtomicMyke's Avatar
The One I have spun a bearing and just decimated the hub.
Old Apr 20, 2016 | 02:01 PM
jensenracing77's Avatar
Is the hub part of the drum? Also, Is one off of a 66 Olds 98 the same?
Old Apr 20, 2016 | 02:36 PM
i would consider the drum to be part of the hub altho they can be separated .to my knowledge they are the same.your spindle didn't get damaged?c
Old Apr 20, 2016 | 02:38 PM
AtomicMyke's Avatar
No I was extremely fortunate that it Come out relitively un scathed, thought if I had to drive it any long that might not have been the case
Old Apr 20, 2016 | 03:16 PM
Octania's Avatar
The problem then becomes if you need the drum on/with the hub... pricey shipping, and finding a drum that isn't beyond use.
Old Apr 20, 2016 | 03:18 PM
AtomicMyke's Avatar
Is it possible that a 65 impala hub would interchange with mine?
Old Apr 20, 2016 | 05:24 PM
Charlie Jones's Avatar
Phantom Phixer
No
Old Apr 20, 2016 | 05:39 PM
AtomicMyke's Avatar
No
Is there a difference in the spindles?
Old Apr 20, 2016 | 08:33 PM
Phantom Phixer
The hub is different because the bolt pattern on the Olds is 5" on5 . The Chevy is 4 & 3/4" on 5. the inner wheel bearings are different too so I would have to say that the spindles would be different too.
Maybe someone with a Hollender interchange manual will chime in and can tell you what else might interchange.
Olds, Pontiac and Buick shared little chassis parts interchangability with Chevy in full size cars before 1971.
Old Apr 20, 2016 | 08:35 PM
AtomicMyke's Avatar
Ahhh I See, well I appreciate the information. Thank you
Old Apr 21, 2016 | 07:26 AM
lemoldsnut's Avatar
So, Mike as we talked yesterday. Hub/and drum. I will pull one for you today and inspect it as we discussed.
Per Hollander there is an early and a late hub size. One is 1 25/32" Early, and the late is 2 5/64" So make sure you check that and I will too.
My car has a build date of 04A so most likely a late. But, as I said I will check today.
Larry
Old Apr 21, 2016 | 12:30 PM
lemoldsnut's Avatar
So as soon as you find out let me know, I have one off and ready.
Larry
541-815-4363
Old May 10, 2016 | 04:28 PM
AtomicMyke's Avatar
Still in need of an early hub/drum for a '65 with the 1-25/32" spindle size.
Old May 10, 2016 | 05:29 PM
oldolds88's Avatar
ill check the 65 i have tomorrow
Old May 10, 2016 | 05:34 PM
AtomicMyke's Avatar
wonderful, thank you
Old May 11, 2016 | 07:02 PM
oldolds88's Avatar
build date on mine is 08C, didnt have time to get the wheel off to measure,so i took the date from the tag
Old May 11, 2016 | 08:17 PM
AtomicMyke's Avatar
Ok, the date code on mind is 01B, however I don't remeber what month it was that the change in hub size occurred
Old May 12, 2016 | 07:10 AM
oldolds88's Avatar
let me see if i can get the thing off today between raindrops
marxjunk
Feb 24, 2015 06:45 PM
wesste
Jul 7, 2013 04:32 AM
jankyrre
Brakes/Hydraulic Systems
Jan 1, 2013 03:09 PM
christl
Jul 24, 2012 02:42 PM
akins2000
Feb 14, 2012 01:09 PM
