1965 442 Shifter Boot Non-Console
GM still sells one, go here http://www.gmpartsdirect.com/results.cfm , if the boot doesn't come up enter this part# 3842926 and see if it is the one you need. If so you can get from any GM dealer, just use the part #. GMpartsdirect.com charges a lot for shipping.
Good luck
Good luck
The rough surfaced one at Fusick's is used as the lower boot at floor pan on console equipped cars. Fusick sells the smooth non console boot also.
I got mine from Fusick and it is duller and slightly rougher than the original but is acceptable in my resto of my 67. The original mounting ring does work with the repro with only 1 or 2 screw holes not in line which can be punched easily.
BeenThere
June 27th, 2015 12:04 PM
nj_cutlass72
April 3rd, 2015 06:43 AM
fast67vellen2o
December 21st, 2012 11:31 AM
fast67vellen2o
July 8th, 2012 10:01 AM
fast67vellen2o
July 5th, 2011 09:42 AM
