1964 Oldsmobile 98 front wheel hub
Old Sep 23, 2020 | 06:36 PM
ACs64Ninety8's Avatar
Hello. I have a 1964 olds 98 that I purchased with a broken wheel stud on the front drivers side. I bought a new stud, pulled everything apart, got it into my vice and managed to crack the hub removing the busted stud. Any leads on finding a hub to replace it would be greatly appreciated. I’m located in Fort Wayne, IN but I’d be interested in shipping something here. This was the last thing needed to get on the highway and it is seriously bumming me out. Thanks in advance.
Old Sep 25, 2020 | 09:50 AM
Don R.'s Avatar
Can't help with a replacement but those studs are swedged in place, the only way to correctly remove them is to grind off the back part and drive them out back to front - learned this the hard way.
Old Sep 25, 2020 | 03:22 PM
jaunty75's Avatar
Originally Posted by Don R.
swedged
swaged
Just to try to avoid any possible confusion.
Old Sep 25, 2020 | 04:44 PM
rocketraider's Avatar
Oldsdruid
My 11/73 parts book indicates 1964 is a year unto itself, but good thing is it can come from either right or left side of any 1964 88/Starfire/Jetstar I or Ninety Eight except a Jetstar 88. That may make finding one easier.
Jetstar 88 uses 5×4-3/4" bolt circle and smaller brakes. Jetstar I uses 5×5" bolt circle and same brakes as Dynamic 88.
Old Sep 26, 2020 | 05:26 AM
I really appreciate the replies! Looks like I’m at a stand still until I find a parts car.
Old Sep 26, 2020 | 07:23 AM
newmexguy's Avatar
I have access to a Parts Car, but it is a '63. It has Left hand 1/2" - 20 studs on the left side of the car. It appears to be 5 x 5 wheel bolt circle. The remaining wheels with car look just like mid seventies 2wd Chevy pickup. If usable, let me know.
Dave S Dona Ana NM
Old Sep 26, 2020 | 09:40 AM
Oldsdruid
Those LH threads may be the only difference between 63 and 64 as 59-63 applications show a RH and LH part number. The steering knuckle/spindle itself is same for 63-64 pn 384933 LH exc F85 or J88.
62-63 exc F85 or 63 Starfire hub/drum pn is 588073 LH, 588072 RH. 64 both sides is 382682 exc F85, J88 or Dynamic 88 police car.
You could change out the 63 hub lug studs to RH threads, though I know you're gunshy of that right now. If you don't, you will have to be careful till the end of time to keep a knucklehead mechanic or tire changer from wringing them off.
Old Sep 26, 2020 | 09:51 AM
Oldsdruid
More info:
Front wheel bearings are the same 62-73 exc F85, Toronado or J88, 7450700 inner.
Outer race 7450697 62-74 exc F85, Toronado or J88. So nmg's 63 hub ought to work for you.
Old Sep 27, 2020 | 04:00 PM
Newmexguy, I’m interested for sure. I sent you a message. Again, thank you guys for this great info!
Old Jan 22, 2021 | 09:57 PM
I’m happy to report that I finally solved my hub replacement issue. I’m installing Scarebird’s disc brake conversion brackets and hubs. I ordered the LAST available pair of calipers and rotors from rock auto last week and finished swapping the drivers side this evening. I’m running 15” Buick Riviera wheels that I believe might need a small (1/4”) spacer to keep them off the caliper. So far it has been a great project.
Old Jan 23, 2021 | 07:26 AM
Oldsdruid
Wasn't aware Scarebird was doing front discs for those years. They've offered a kit for the rear for years. What hub/rotor did they set this conversion up for?
At one time any front disc conversion you could find required sending your spindles in for machining. That still the case or did SB come up with a true bolt-on kit?
Old Jan 23, 2021 | 12:42 PM
The hubs are machined by Scarebird and replace the original hub. They also send the new, more common and different than original bearings and seals to match the new hubs. The rest of the parts are off the shelf 69-76 Cadillac eldorado parts. I’m extremely satisfied with how well everything went together. I’m hoping to test drive it tonight.
alaska64
Ninety-Eight
Sep 8, 2020 07:04 PM
Nikojoe
Apr 12, 2019 11:09 AM
fv64olds98
Dec 22, 2016 06:45 AM
dadedave
May 28, 2012 08:45 PM
65olds98
Oct 15, 2008 11:01 AM
