1964 jetstar 88 radiator hoses
Old Dec 24, 2011 | 10:15 AM
belairbob's Avatar
Hi i have a 1964 jetstar 88 330 ci 4 brl i want moulded rad hoses the gates # 20390 upper rad hose they list for this car is incorrect and yes i heve the original motor & rad the hose thats on the car now is #s9b [zero or o] 8g the lower hose is a flex hose. Thats to mickey mouse for me does anyone have part #s for hoses that will fit even if i have to alter them thanks this site has been of great help in the passed.
Old Dec 24, 2011 | 12:16 PM
2blu442's Avatar
Sorry, I don't have a source to share. But this has been discussed in the past and I believe the 1964 330 is a one year only water pump. There may not be a molded hose for this application being produced. Try the search option to find other threads discussing this. Hopefully there will be one that clarifys the situation for you. John
Old Dec 24, 2011 | 04:02 PM
belairbob's Avatar
64 jetstar 88
thanks i'm learning
Old Dec 24, 2011 | 05:00 PM
2blu442's Avatar
Hi Bob
I've got a couple 1964's but they don't have the original engines or radiators. What I remember is the 1964 330 has a water pump that connects with the radiator on the lower drivers side. In 1965 Olds switched it to the passenger side. So the "best" fix if you don't need it to stay original is swap on a newer water pump and change the radiator to have the lower port on the passengerside. A lotta work! But if the water pump goes out or you blow a hose on a trip somewhere you can find the newer ones much easier than the "one year only" parts. Sorry, but I think that's where things are at.
John
Old Dec 24, 2011 | 06:47 PM
belairbob's Avatar
rad hoses
thanks for the advice Bob
belairbob
Sep 27, 2012 07:09 PM
belairbob
Dec 24, 2011 07:58 AM
65cutty
Jun 12, 2009 06:45 AM
Iragh
Nov 17, 2008 03:41 PM
