1963 F85 Clutch
Old Apr 28, 2017 | 01:40 PM
poodlefire's Avatar
1963 F85 Clutch
I'm looking for a replacement clutch kit for my 3speed manual tranny. All the catalogs quote a 10 1/2 dia clutch plate, but my existing plate is only about
9 1/2. Anyone have any suggestions?
Old Apr 28, 2017 | 02:26 PM
jensenracing77's Avatar
I was just down this road. You are going to need to send yours in and have it rebuilt. I have found ZERO available from anywhere. The only option is to rebuild what you have, find good used, or call D&D Aluminum V8 and get an expensive aftermarket light weight flywheel and clutch setup for that flywheel.
Maybe someone else knows something I don't... I hope so
Old Apr 28, 2017 | 02:27 PM
And welcome to the site. Post pictures of your ride if you get a chance. We love pictures
Old Apr 28, 2017 | 02:49 PM
young olds's Avatar
I couldn't find any 9.5" clutches for 10 spline input shaft. You can go up or down a bit in diameter but idk how the contact will be on the flywheel and personnly wouldn't attempt it.
Old Apr 28, 2017 | 07:20 PM
1k442's Avatar
poodlefire
You will not find a kit. There are a few clutch discs on Ebay. The pressure plate should be able to be resurfaced local. A machine shop that works on flywheels should be able to do it. Back in the 1980's I needed a clutch disc for my Cutlass. Went to the local auto parts place. When he looked up the cutlass I noticed the same clutch disc was used on a plymouth valiant, ford falcon and a few other cars. Just measure the spline od and haw many teeth and get one that fits. I am not home till friday next week. I have some used units I can measure. I will let you know then.
Old Apr 29, 2017 | 12:18 PM
Originally Posted by barron1941
You can try Kanter.com they show a disc,pressure plate & throw out bearing in there catalog.800 526 1096
They require a core and last I checked they had none in stock. You would have to send it to them just for them to have it rebuilt. Would be worth the call but if it is not in stock I would just send it to someone yourself to be rebuilt
Old May 2, 2017 | 06:58 AM
poodlefire's Avatar
Thanks everyone for the suggestions. I think I've found the answer from hrclutches.com who can put together a kit from stock rebuilt parts.
RandyS
Jul 6, 2021 07:45 PM
trackz man
Aug 29, 2016 04:32 PM
47 Convertible
Apr 3, 2014 07:56 AM
RandyS
Mar 8, 2014 05:07 AM
ptva
Jan 5, 2007 03:25 PM
