14x6 SSII rims
Old May 3, 2009 | 05:47 PM
dan1s's Avatar
14x6 SSII rims
Looking for (4) SSII rims for my 68' 442. Don't need the trim rings or center caps.
If you live in NY or close by please let me know.
Thanks, Dan
Old May 3, 2009 | 07:39 PM
SIPLOWGUY's Avatar
I have 5 SS3 wheels if you are interested e-mail me at siplowguy@aol.com or call me at 917-566-2621. I'm in Staten Island.
Old May 3, 2009 | 07:45 PM
dan1s's Avatar
Siplowguy, thanks but I'm only looking for the 14x6 (1968) SSII rims. These should have the bolt on center caps
Old May 3, 2009 | 08:01 PM
SIPLOWGUY's Avatar
OK mine are the snap on.
Old May 3, 2009 | 08:05 PM
SIPLOWGUY's Avatar
Check out this post for your wheels:https://classicoldsmobile.com/forums...5-pattern.html
Old May 3, 2009 | 08:07 PM
ent72olds's Avatar
Registered Luser
Dan, where in NY do you live, I'm in LI and I believe I have what you need! I'll check and make sure! If so, I'll PM you!
Old May 3, 2009 | 08:23 PM
dan1s's Avatar
Erik,
I live about 1-1/2 hours north of the city. Please let me know. Thanks, Dan
If you have pictures you can send them to dan442@optimum.net
Old May 3, 2009 | 08:42 PM
ent72olds's Avatar
Registered Luser
Will do!
Old May 4, 2009 | 08:51 AM
wmachine's Avatar
Trying to remember member
'68 and '69 14 x 6 SSIIs are the same. Should be stamped "14 x 6 JK" with "810".
They have the same caps, and different trim rings. '69s have the 5 stainless bezels, and with '68s, the rim around the holes are painted (no bezels).
Old May 4, 2009 | 08:57 AM
dan1s's Avatar
What's the difference in the trim rings? I knew about the stainless bezels and caps.
Old May 4, 2009 | 09:00 AM
If you were ever going to pass thru Gawga on your way to Florida, I've got some extras.
Old May 4, 2009 | 10:41 AM
wmachine's Avatar
I'll have to check to be sure which year is which, but I think it was '68 that the rings are more burnished/satin than the '69 ones. Along with not remembering which year was which, I also don't recall the explanation for it either!
The rings for both years are relatively shallow, too. The hole for the valve stem is *not* enclosed, but open on the inboard side.
The few times that I've looked at '68s and '69s at car shows the last couple of years, I've noticed that very few of them have correct rings.
Old May 4, 2009 | 11:21 AM
dan1s's Avatar
Here is the information that I was going by.
http://www.oldsmobility.com/superstock.htm#NOTE%201
Old May 4, 2009 | 11:48 AM
wmachine's Avatar
Keith hasn't updated his info there for quite a long time and a some of it just isn't correct. Which reminds me as soon as I get this info sorted out (again), I'll update the Olds Wiki (FAQS).
Like the SSII was *not* introduced in '68 as option N66, it was introduced as option P05 taking the place of the SSI in 1968. In *1969* (and there forward) it was option N66, as the SSI was brought back as option P05.
Old May 4, 2009 | 04:13 PM
ent72olds's Avatar
Registered Luser
Dan, with all of that said, I do have 4 ssII's. Today was rainy, and they are in 3 different locations but I do have a set. If still interested, I will post pics tomorrow or Wednesday. I'll also try to get some #'s off of them. I know they need to be painted.
Old May 4, 2009 | 05:13 PM
dan1s's Avatar
Thanks, I sent you a PM
Old May 4, 2009 | 06:10 PM
wmachine's Avatar
Okay, found my info on the trim rings. '68 trim rings were a more brushed/duller finish, and the '69s were bright/shiny. *Apparently* the '68s were considered to be too dull (being used to the SSI shine), and it was spiffed up for '69.
ceaton
Nov 18, 2014 04:42 PM
LJA72
Jan 31, 2014 08:02 PM
MrLightning
May 17, 2012 04:58 PM
MrLightning
May 1, 2012 02:46 PM
70W30Jim
Jan 21, 2012 06:39 AM
