12 bolt 'O' posi units back in 3 series Eaton
Old Sep 28, 2015 | 01:45 PM
monzaz's Avatar
New 12 bolt 3 series Eaton posi units are back -
495.00 for Classic Oldsmobile.com members
shipping will depend on distance from 44286
Thanks, Jim
J D
330 990 8155 or PM me
Old Sep 28, 2015 | 04:08 PM
Jim,
Can you clarify which gears these are for? I know the Richmond gears are a different series than the factory Olds gears and I wanted clarification on exactly which ones fit these diffs.
Old Sep 30, 2015 | 04:07 AM
monzaz's Avatar
3 series ratios
3.08 3.23 GM gears
AND
Richmond 3.42 and 3.90 gears
WILL NOT fit 3.42 3.90 4.30 GM original gears.
Jim Mitschke
J D Race
Old Oct 1, 2015 | 07:10 AM
GEARMAN69's Avatar
Jim are these 28 spline or 31 ? 8.8 Ford conversions I assume so does it need the 45/90 degree spline axles like a 71-72 8.5 or the 30/60 degree 28 splines like 70 and older type O ?
Old Oct 1, 2015 | 05:14 PM
monzaz's Avatar
12 bolty olds 28 spline
These are 28 spline. We have not had any slop issues with the splines on the side gear to axle fitment. These are the 8.8 ford units Yukon Eaton.
We have only one 8.8 31 spline unit left on the shelf. Standard 's' spring trac lock unit.
J D
Jim
Old Oct 4, 2015 | 02:56 PM
Uncle Hulka's Avatar
Ancient Olds Lover
Can this directly replace the open carrier in a 1969 O-type Olds rear (12-bolt cover)? Will this accept the stock Olds axles from same?
monzaz
Sep 13, 2013 10:33 PM
68Tom
Apr 24, 2012 12:39 PM
68Tom
Apr 17, 2012 10:47 AM
monzaz
Apr 24, 2011 06:12 PM
oldzy
Drivetrain/Differentials
Sep 7, 2010 05:14 AM
