64 F-85 Harrison Radiator
I had the original 3 core Harrison radiator rebuilt locally in Dallas, Had the bottom outlet moved to the passenger side so when servicing the water pump you can use a 65 and up water pump. I poured coolant in once to start the 330. drained it and that's it. It's basically new. $125.00 plus the ride from the DFW area.
I don't believe so the core support is different.
radiator Dimensions:
Total: 21.75" tall (with cap) x 25.5" wide
Core: 15.75" tall x 25" wide x 1.75" thick
Inlet: 1.5" driver's side
Outlet: 1.75" passenger side
Tanks: 2.75" thick (top), 2.38" thick (bottom)
Tubes: 0.75" thick
Tubes: 0.75" thick
like therobski said its not the same. i do have one from a 63 starfire that may fit. i was told it was the same for 64 starfire but not sure about jetstar.
