73-77 Cutlass Posi Rearend
Old Nov 20, 2014 | 12:48 PM
firefighter5174's Avatar
Sold
Old Nov 25, 2014 | 07:59 PM
74hurstolds's Avatar
Car Farmer
Is that the original series 2 carrier in there or the series 3 for the lower gears? I think the series 2 has a 726 stamped in it whereas the 3 has a 725. Do you happen to know what spline axles are in there, 28 or 30? Bolt in axles?
Old Nov 25, 2014 | 11:29 PM
nsnarsk65cutlass's Avatar
That's an awefully thick ring gear my bet is that is the 2 series carrier.
Old Nov 26, 2014 | 05:55 AM
monzaz's Avatar
rear end info for you all
oK...
-1ST OFF gm 10 BOLT 8.5 DOES NOT HAVE A THICK GEAR SET...no such thing.
so that means it is a 3 series carrier OR it is set-up wrong!!! Oh Boy... lets hope all the correct parts are in there. as the pattern TO ME looks to be ok. FROM WHAT I can see.
-2nd gm never produced a 30 spline 8.5 bolt in axle rear.
so this rear is 28 spline BIA rear with stock BIA posi 726 (2 series) 725 (3 series) casting as stated in a earlier post.
30 SPLINE IS ONLY AFTERMARKET IN THE BIA SET-UP
IF you look on the back side of the carrier flange area deep in the webbing you will see a 7 2 5 or 7 2 6 one number in each web cavity so then you know what carrier these gears were installed on.
If they were installed on 726 carrier watch out...
IF YOU THINK 4.30 IS THICK YOU SHOULD SEE THE 5.57 RING...LOL
Old Nov 26, 2014 | 10:21 AM
Car Farmer
Although it could be wrong, I've found conflicting information on this various places on the web stating that some do have 30 splines depending on the year/application. Maybe it was geared to only C-clip types.
http://www.crankshaftcoalition.com/w...identification
A few months ago I had Bob Kelso from Rocket Racing build me a BIA 3.42 axle with a 725 carrier all from a 11/9/1973 date stamped rear end axle housing. The type 3 carrier and axles were original to it. From what I recall in our conversation, I want to say that it had a 30 spline axle in it because I remember asking and being surprised to hear that, but I could be wrong. I could pull the axle out and check the spline count on it. It's out of the car right now with no breaks assembled on it.
The gear in there has a Richmond part number on it and looks to be for a 4.10. I've never heard of a 4.30 for an 8.5 10 bolt.
I agree that this must be a type 3 carrier. Looking at Richmond's site, they don't offer gears for the type 2 that are thicker, as they do for the Chevy 12 bolt 8.875 rear.
Old Nov 26, 2014 | 10:33 AM
oldsmobiledave's Avatar
Fyi
I have owned two 1973 3.42 posi 10 bolt differentials. Both had bolt in axles & 28 splines.
Old Nov 28, 2014 | 04:56 AM
GEARMAN69's Avatar
For the record. The 8.5 only has a 2 series which is 2.41 -2.56 and a 3 series carrier. 2.73-----All the way... All 8.5 are 28 spline 1971-1989/90. In 1989/90 they switched to 30 spline on all to present.
Old Dec 3, 2014 | 02:33 PM
Sorry guys, Im just getting back on here and never got any notifications that someone had responded.
I got this rear when I bought out 3 storage lockers from an individual a couple months back. He told me he had someone build this for one of his cars that he ended up selling before installing. So I know very little about what exactly was done to it. Everything inside looks nice, but I don't know much about rear ends.
You are correct on the gears, they are 4.10s. Im not sure where or why I thought they were 4.30s. As for as the carrier, I will pull the cover and check tomorrow when I get back home, weather permitting, and let everyone know.
Old Dec 4, 2014 | 06:34 AM
Bob Kelso's Avatar
Nick , the axles in the rear end i built for you are 28 spline ,which are stock . BOB
Old Dec 4, 2014 | 06:57 AM
Car Farmer
Thanks Bob!
Old Dec 8, 2014 | 05:43 PM
It is a 726 posi unit. So, since it wasn't put together properly I guess I will be taking it apart and scrapping the housing. If anyone is interested in the gears or posi unit let me know. Not sure when Ill get around to taking it apart, but it will be on my to do list.
Old Dec 13, 2014 | 12:15 AM
1973hurst's Avatar
I might be interested in the posi unit. If it's still available and I live in the St. Louis area. My email address is tkd_67206@yahoo.com. Thanks Craig
Old Jul 14, 2015 | 02:12 PM
Car Farmer
Did you ever scrap or sell this? I could use that rear end cover plate.
Old Jul 14, 2015 | 02:53 PM
It's all gone.
oldgeardad
Oct 27, 2013 10:37 PM
reesejames
Jun 6, 2010 05:30 PM
copper128
Mar 6, 2010 11:32 AM
wash464
Aug 26, 2009 05:47 AM
DennisG.
Mar 22, 2008 06:20 AM
