10 bolt 4:10 posi rearend
Old Jan 17, 2014 | 06:52 PM
Bob Kelso's Avatar
This is a 71-72 Buick GM A body 10 bolt 8.5 rear with the bolt in axles . It has the Eaton newer style posi , Moser axles with long 1/2 by 20 studs , HD retainer plates , 4:10 after market ring and pinion , new upper control arm bushings , drum to drum . Brakes are in excellent condition and probably just need to be bled . Tubes are welded at the center section for strength . This is a low usage rear end and is in great shape . Posi is a Eaton # 19557-1. Ring and pinion are marked GM10-411-MW-10x41. These are Mark Williams ring and pinion and the good Eaton posi .See pictures . Rear could use a little clean up from dust and sitting around but is very clean with no pitting .Asking $775 , Pick up in Hebron Illinois , zip 60034 prefer pick up and cash . thanks BOB
Last edited by Bob Kelso; Jan 19, 2014 at 10:44 AM. Reason: Adding info and pictures
Old Jan 19, 2014 | 10:46 AM
Bob Kelso's Avatar
Added part numbers and photos
Old Jan 26, 2014 | 04:33 PM
devmar07's Avatar
Interested, is it totally ready to bolt in.
Old Jan 27, 2014 | 06:18 AM
Bob Kelso's Avatar
Yes , you would need the brake lines and bleed the brakes . Can inspect when purchased so you are satisfied on condition . BOB .
Old Jan 27, 2014 | 07:33 AM
chadman's Avatar
This is a great deal. Someone should jump on this.
Old Jan 27, 2014 | 03:32 PM
p518's Avatar
What spline are the axles?
Old Jan 28, 2014 | 06:40 AM
Bob Kelso's Avatar
Axles are 28 spline . BOB
Old Jan 28, 2014 | 07:15 AM
507OLDS's Avatar
It's the ratio that is holding people back,but with a lot of you guys converting to overdrive transmissions,this is perfect.
Old Jan 28, 2014 | 07:31 AM
p518's Avatar
I have 28-spline in mine. I would jump on this if it were 30 or above. The ratio doesn't bother me. I have 3.90's now.
Old Jan 28, 2014 | 08:22 AM
oldsmobiledave's Avatar
my experience
This rear end is a fabulous deal. Unless you are running mid 11s or faster the 28 spline axles are fine. For most street cruisers this rear end will be more than adequate. A 28" tall rear tire will help tame that 4.10 ratio.
Bump for an excellent item at a fair price. Good luck with the sale.
Old Jan 28, 2014 | 08:33 AM
p518's Avatar
My car is around 3600 lbs. and runs low 12's to high 11's depending on weather and the setup. I was twisting the splines on my stock 28 spline axles, so I went with aftermarket ones. Of course, I run a spool. That makes a difference. I would just want to upgrade the spline (for me) at this point. Wish now, I would have spent the money before when I had the chance and it was apart.
Old Jan 28, 2014 | 03:53 PM
507OLDS's Avatar
P518,
What rear are you running?
Old Jan 28, 2014 | 05:04 PM
p518's Avatar
8.5" corporate 10-bolt
Old Jan 28, 2014 | 07:03 PM
Magna86's Avatar
I'd be all over this if wasnt so far away great deal.
Old Jan 29, 2014 | 07:07 AM
507OLDS's Avatar
I haven't had any issues with the stock 28-spline shafts,in an A-body,running 11:70's or slower.They have been in the 3800-4000lb range,slicks or drag radials,and foot brake. A clutch,trans brake,or anything else that adds a blunt force at home plate,would put more stress on the shaft.
The aftermarket axles,like the Mosers,are made of a better material than OEM,and can take even more abuse,even with the same 28-spline.
If I built a rear,like the one above,it would be $1600.00. You can't build it,even with factory shafts,for what Bob is asking.
Old Jan 29, 2014 | 07:26 AM
p518's Avatar
I know. You are correct. This is at the very least a $950 to $1200 differential. BTW, I foot-brake, too.
Old Jan 29, 2014 | 07:37 AM
Iggyg00's Avatar
wish it was closer but a 15 hour drive is rough.
Old Mar 9, 2014 | 05:43 PM
11971four4two's Avatar
MOTORHEAD
posi feedback
Thanks BoB
i will try to get the axle installed soon
nice to meet the man
thanks for your service to our country
glad you were able to come home and buy that w31
and still own it today!
Thanks Again!
have fun pulling wheelies in the Olds Mobile
brian
Magna86
Apr 2, 2015 10:44 PM
Qwik71442
Sep 19, 2013 04:11 PM
ScottoW31
Feb 21, 2012 03:36 PM
Bob Kelso
Jul 1, 2011 07:01 AM
Curth
Sep 22, 2010 07:28 AM
