455 block,steel crank,hyd roller lifters misc
Old Sep 2, 2013 | 04:09 PM
nine8's Avatar
70 455 F block fresh .060,completely machined and readdy for assembly,arp main studs,arp head studs $750
455 steel crank shaft fully raceprepped,cut 10 under,with flexplate and balancer $500
Comp hyd roller lifters never used $250
Milidon 455 7qt pan brand new $200
Edelbrock aluminum rpm heads milled to 76cc,compitition valve job,gasket matched,lightweight valve,hyd roller spring and retainer upgrade,included harland sharp roller rockers $1800 new never used
Pontiac ram air 455 .060 pistons $300 new
425 rods that we're completely prepped but damaged from flood/rust will need to be shotpeened or blasted $150
425 steel crank and flexplate std not cut $200
2 70 455 F blocks and cranks one is std one is .030 and has to go 60 $400 for both or they. Get scrapped
I do not have pictures,located in north new jersey please CALL ME 201 993 6890
Old Oct 7, 2013 | 04:42 PM
Oldzman71's Avatar
Hi do you still have the roller lifters? Thanks ryan
Old Oct 8, 2013 | 05:48 AM
nine8's Avatar
Yes
Bernhard
Nov 24, 2022 09:12 AM
jims2000lt
Nov 20, 2014 05:27 PM
rcktdoc
Jul 14, 2014 04:19 AM
oldzy
Aug 6, 2011 05:28 AM
sx455raidercelticfan
Nov 23, 2010 05:45 AM
