64' - 72' Cutlass OEM Front Control arms- blasted\ powdered
Old Aug 3, 2013 | 12:50 AM
JCMC64's Avatar
JC
64' - 72' Cutlass OEM Parts
Selling a bunch of restored parts with profits going towards the "paint my car fund!"
Also have a boat load of other media blasted and Powder coated parts, all in Satin black P\C that look just as awesome\ minty, and paint as hard as concrete:
PARTS BELOW ARE MEDIA BLASTED AND ELECTRO POWDER COATED TO LOOK NEW!
- 3 KH steering pump pulleys, one solid pulley, 2 with holes $50 each
- One 3 groove crankshaft pulley $50
- OEM High Heat Powder coated 10 bolt diff cover with original restored bolts - $80
Also have almost new rear drums for $20
- OEM 70-72 Brake Prop valve. Valve carefully blasted and Por15 Aluminum heat painted, mounting bracket media blasted and powder coated. $65
OTHER MISC things:
- NEW Ralley Pac gauge faces for Oil\Temp\Fuel gauges unit. $50
- 68-72' NEW gas pedal GTO \ Grand Prix\etc $15
- 68-72' OEM Black Front Arm rest Base w\ chrome trim off 70' 442 very nice. $40 (pics below)
- Cutlass Bumper Guard rubber inserts, Driver quality. One mount thread broke off. $20
- 68-75' OEM 455 4barrel intake manifold, blasted and POR15 aluminum heat paint $135
- 68'-75 OEM 350\455 Thermostat housing blasted and POR15 aluminum heat paint
inside and out - $40
- OEM 350\455 Timing cover, blasted and primed with high heat primer, with new crankshaft seal- $40
- 455 Chrome engine and TH400 Tranny oil dipsticks...NEW unused $25
- Air deflector- very good cond., clean $40
- New in box TIMKEN Bearings and Seals for 28\30 spline axles $45
- Very decent OEM 68-72' steering rag joint, no tears, all there $15
- New GM 71'-72' M&H #17565 TH400 Trans Gas pedal switch to engine harness $20 shipped.
This one- http://www.opgi.com/p/wiring-harness.../34/17565.html
- 70-72' Gas tank. VERY CLEAN! Was going to keep and use it till someone practically gave me a new tank. I also have the gas straps that are painted and very clean too. $50
- 70-72 driver side black kick panel SEM painted, looks new. $30
- 70' 442 Chrome window trim molding
- 70' 442 Headliner windless - all the way around
Lots more stuff to come, Just ask
SOLD Items:
-68-72' Bumper front mount brackets (off a 1970 442)- Front $130 SOLD
-68-72' Bumper rear mount brackets, some pitting, but solid (off a 1970 442)- Rear $100 SOLD
-OEM High Heat Powder coated Original Delco Moraine Rear drum backing plates, with new Wagner brake shoes and spring kit - $150 SOLD
-68'-72' Front Bumper brace \supports - $various SOLD
-68'-72' Power Steering brackets (One set from a 70', one from a 72') $75 a set SOLD
-68'-72' Alternator brackets 1 set $85 SOLD
-70-72' AC brackets - Passenger side setup. Got one almost complete set - $150 SOLD
-68-72' AC Condenser brackets with rubber mounts $65 SOLD
-68'-72' OEM front sway bar mounts with reconditioned clean oem bolts $30 SOLD
-70-72 OEM caliper brackets. Media blasted look mint. $30 SOLD
-AC compressor shield\guard $20 SOLD
-Cutlass New AC relay switch $10
-71' Cutlass Complete AC ducting system including distribution duct...no cracks, chips, holes, etc in plastic parts. Ducting is in real good shape. Just very tiny issues if at all. $200 for complete set.
-Restored Fresh air duct in awesome restored shape, painted metal flap with POR 15 silver - $40
Full set of OEM 64' -72' front upper and lower control arms.
I had these media blasted, and had them real deal powder coated in Semi-gloss black\Satin. They look mint cond and are hard as concrete. $400 + actual ship cost SOLD
Old Aug 3, 2013 | 12:58 AM
JCMC64's Avatar
JC
Just some examples of how nice this stuff came out:
Old Aug 3, 2013 | 01:04 AM
JCMC64's Avatar
JC
I have the OEM bolts for these sway bar mounts SOLD
Various 68-72' Pulleys - Crankshaft\ Power Steering
Old Aug 3, 2013 | 01:10 AM
JCMC64's Avatar
JC
Old Aug 3, 2013 | 01:17 AM
JCMC64's Avatar
JC
350-455 thermostat housings - blasted and Hi heat paint. One in middle is a repop from Parts Place
Old Aug 7, 2013 | 01:58 AM
JCMC64's Avatar
JC
Old Aug 12, 2013 | 03:37 PM
JCMC64's Avatar
JC
Old Aug 22, 2013 | 06:53 PM
JCMC64's Avatar
JC
68-72' Cutlass\ 442 Power steering brackets SOLD
Old Sep 3, 2013 | 12:29 AM
JCMC64's Avatar
JC
64-74' Olds\ Cutlass \ 442 Oem original factory Delco Moraine Backing plates with original mount bolts and hardware SOLD
Old Sep 9, 2013 | 04:45 PM
stlbluesbrother's Avatar
Just wanted to report back on some powder coated items I bought from Jim. All were in dynamite (show) condition. Communication was also excellent. I'd definately buy from him again.
Mike
Old Sep 10, 2013 | 02:56 PM
70vert's Avatar
Where are you located? I want the gas tank but shipping it would probably be too costly.
Old Sep 11, 2013 | 06:10 AM
JCMC64's Avatar
JC
Thx Mike!
70 Vert, Im in Ft Lauderdale, FL.
Old Sep 11, 2013 | 10:49 AM
JCMC64's Avatar
JC
350- 455 oil adapter, blasted and POR15 hi heat paint - $40 SOLD
Rear diff pinion seal - $10 free ship
Oem 4 barrel Cable throttle bracket, media blasted and clear coated- $15 SOLD
Old Sep 14, 2013 | 01:00 PM
JCMC64's Avatar
JC
Updated sold items, added some more items...will be adding more this weekend.
Old Sep 15, 2013 | 02:25 PM
JCMC64's Avatar
JC
68-72' Cutlass\442 front Arm rest base with chrome trim - $40
Cutlass AC relay switch $10
69-72' GTO \ Grand Prix Gas pedal $15
Bumper brace rubber inserts, Driver cond - one mount thread missing $20
Old Oct 30, 2013 | 01:01 PM
JCMC64's Avatar
JC
ttt
Old Nov 17, 2013 | 05:57 PM
JCMC64's Avatar
JC
ttt
Old Nov 17, 2013 | 06:37 PM
OIF2010's Avatar
I want the arm rests and a thermoatat housing shipped to 35211
Old Nov 18, 2013 | 06:00 AM
JCMC64's Avatar
JC
Check your pm in a little bit.
Thx. Jim
JCMC64
Feb 2, 2019 10:22 AM
DR_DAN
Mar 9, 2015 05:48 PM
oldspackrat
Mar 14, 2013 09:23 AM
Tom442
Jun 14, 2012 08:25 AM
jpaulwhite
Jul 22, 2010 07:01 AM
