1965 442 Engine
Old Jul 20, 2013 | 12:29 PM
65B01Delta's Avatar
1965 442 Engine
I have a 1965 442 400 engine ( I was told). It was pulled in the 80's due to blow by, it's been torn down since the 80's. Crank is for a automatic (not drilled for a stick car). I have all parts to put it back together except for the intake & exhaust manifolds... $400 PM if interested.
Engine is located 30 miles west of Cincinnati, Ohio...
Old Jul 20, 2013 | 12:58 PM
You were told correctly. It's a 1965-only B-block 400. The "V" prefix on the engine unit number pegs it as a 442 motor (which would have been the only application for the B-block anyway).
Old Jul 20, 2013 | 01:27 PM
65B01Delta's Avatar
Thanks, I figured it was a correct 442 engine. Maybe somebody may want it to make their car correct.
Old Jul 20, 2013 | 03:05 PM
tru-blue 442's Avatar
Old School Olds
Oh CRAP! Check out pic #4.
That is one hairy crack in the block, ouch.
Old Jul 20, 2013 | 03:13 PM
Dangerbird's Avatar
where? looks like a casting mark to me.
Old Jul 20, 2013 | 03:16 PM
65B01Delta's Avatar
Your right Dangerbird, it's a casting mark....
Old Jul 20, 2013 | 04:15 PM
ent72olds's Avatar
Registered Luser
Wish you were closer....
Old Jul 20, 2013 | 04:41 PM
TK-65's Avatar
Police Apprehender F85s used the 400 (L77) also.
Old Jul 20, 2013 | 07:44 PM
Old School Olds
Whew! That was close, you know
how some of those hairy cracks can be...
Old Jul 20, 2013 | 08:00 PM
Dangerbird's Avatar
lol
Old Jul 28, 2013 | 11:53 AM
Old Olds Fan's Avatar
Is this engine still available? You have all the main caps, the rods, crank, and harmonic balancer? What condition is the crank in, damaged in any way? Are you willing to create and ship the engine and parts? Does the block have the boss for the clutch linkage pivot on the left side?
Old Jul 28, 2013 | 02:39 PM
65B01Delta's Avatar
I had a a lot of people wanting the engine, but no comment yet, so yes still available.. All the main caps, the rods, pistons, crank, oil pan , front engine cover and harmonic balancer are there. I think I have the water pump also. The crank looked good to me. The guy pulled it back in the day due to blow by.. I can send pictures of all. Yes, it drilled for the clutch linkage pivot ball. Where would I be shipping this to ? Fastenal most likely would be the lowest shipper.
Old Jul 28, 2013 | 05:28 PM
65Bo1Delta, PM sent Old Olds Fan
mosch1888
Feb 27, 2022 04:45 AM
Old Olds Fan
Apr 30, 2015 08:58 PM
805cut
May 3, 2012 08:11 PM
ronman442
Sep 11, 2009 06:29 AM
longboardguy
Jun 15, 2008 12:30 AM
