Olds Posi Rear End 59 61 Axle Race (NW Wisconsin)
Old Feb 27, 2011 | 06:16 PM
warrior71's Avatar
Warrior
I have two old school heavy duty hot rod or drag rear ends that I will entertain offers on. You know what they’re worth and I have a good idea what they are worth, so don’t insult me with a low ball. Contact Frank 715 924 3141 NW WI. email: shadygroveresort@charter.net
59 Quarter Master Rear End ($1975)
The first is a pro built drag rear axle (Built by Quarter Master Racing), that was on a 66 Chevelle Dragster using part stock suspension and ladder bars.
Full spool 5.57 gear Ring gear 39 teeth – Pinion 7 teeth
Welded ladder bars and brackets
Sway/stabilizer bar and bracket
Cast Date is L 24 8 (Dec 24 1958)
Third member housing Casting number 522486
31 spline axles 29 ¼ inches in length from hub to spline
Housing is 54 inchs from inner backing plate to inner backing plate
Includes backing plates and new brakes, hardware, wheel cylinders
Brake drums included, very good condition
The second is a 1962 Olds Posi rear end ($1250)
2.87 posi Ring gear 43 teeth – Pinion 15 teeth
31 spline axles 30 1/8 length from hub to spline
Cast Date is K 15 0 (Nov 15 1960) from an Olds Super 88
Housing is 55 3/4 inchs from inner backing plate to inner backing plate
Includes backing plates, wheel cylinders, and hardware
Brake drums included, fair useable condition
Gasser Drag Racing Hot Rod Chevelle Pro Street GS Buick 442 SS GTO Cutlass Ford Mopar Dodge Mustang Chearge Cuda Challenger Dragster 1959 1960 1961 1962 1963 1964 1965 59 60 61 62 63 64 65 Rat Rod Street axel Custom Restomod Resto Mod Modified Altered Funny Car
Old Feb 28, 2014 | 07:52 AM
r7777s's Avatar
do you still have the rear ends Olds posi and Spool.
Bob Kelso
Apr 4, 2015 08:19 AM
scooter123
Jan 20, 2014 09:53 AM
Bob Kelso
Nov 16, 2012 01:21 PM
monzaz
Nov 14, 2012 07:20 PM
507OLDS
Sep 11, 2011 07:37 PM
