I’m offering this ‘70-72 manual transmission console insert recently coated in SEM Landau Black with driver grade (rechromable) boot frame with all studs intact. The plastic tabs are gone on the adapter. There were typical chips in the corners of this adapter that have been repaired by me. Structural aluminum sheet metal backing with kydec replacement inserts bonded and blended with Hysol 934 two part aviation structural adhesive. I’m in process of wrapping up a restoration on an automatic console which will be for sale in the future. If you’re interested in a full manual console, I can make that happen as well for additional pricing. $85 plus shipping
I fabricated some steel mounting tabs in lieu of the broken plastic tabs and bonded them on. Once the rubber boot is installed with the chrome trim ring, the tabs will also be held on with the studs. I had to do the same thing with my insert, and it works very well. Price is still $100, just a nicer piece.
