I was led to believe these are 1968 Cutlass hood hinges, if not I'm sure I'll be corrected promptly. If they are truely 68 hood hinges, what you see is what I have. I do not have the springs. One is in very nice condition ( driver side), the passenger side shows past rust pitting. 100.00 for the pair. Prefer local pickup but will ship if if you twist my arm.
Those are indeed a 68 Cutlass/442/Vista/F85 hinges.
68s have the two hole mounts like the hinges in your picture.
69-72 have 3 mounting locations.
Original 68 fenders only have two weld nuts to mount the two-hole hinge.
Replacement fenders for a 68 typically have the 3rd weld nut so they can be used with a 68 or a 69.
Google and a search here is your friend if you need further visual verification.
And to add....
These are the second version of the 68 hinges that added a third hood mounting hole location. Until September or October of 67 the hinges only had two bolts (and holes) on the hood side.
