69 70 71 72 Cutlass 442 2 or 3-Core Radiator Top Plate --Real GM
Old Jan 12, 2025 | 09:03 AM
ros6872's Avatar
ros6872
69 70 71 72 Cutlass 442 2 or 3-Core Radiator Top Plate Real GM
Stripped and painted top plate for cars with AC (plastic fan shroud)
$95 plus shipping from 06410 CT
Enjoy real GM quality and fit
I have lots of nice OLDS stuff-- contact me with needs
www.ros6872parts.com
I can accept Paypal, credit card via phone, check or money order-
203-651-9990 or email ros6872@hotmail.com
thanks for looking!
Old Feb 12, 2025 | 02:47 AM
ros6872's Avatar
ros6872
still available
Old Feb 20, 2025 | 12:34 PM
72OldsCut<'s Avatar
Barry
So that will not work with a 4-core radiator?
Old Feb 20, 2025 | 01:53 PM
70Post's Avatar
What he is selling is for a 3 row radiator....not a 4 row.
Old Feb 20, 2025 | 06:03 PM
72OldsCut<'s Avatar
Barry
Patton,
I have been studying the 1972 Cutlass Assy Manual on the GMpartswiki. Page 323 of that shows a chart of 1972 radiator usage. It gives part numbers, but I can find no other descriptions of the various radiator configurations. In other words, I can't tell from this chart (or anywhere else) which is the 2-row, 3-row, or 4-row radiators.
Looking at the first row of the chart, I can ASSUME that the radiator part # listed under the Y72 (HD cooling) column is a 4-row. And in the last column labeled "STD" I can ASSUME that this is a part number for a 2-row radiator. Assuming is not a good method. Other than that, I can't determine what is the correct radiator for a 72 Cutlass with L34 engine (350 with 4bbl) and air conditioning (the part # is in the the "C60/C61" column). That box of the chart shows part number 3027544 (how many rows??). And that part number has been superceded by #3030100 (how many rows on that one???).
All I want to know is how many rows of radiator to get for a 72 Olds Cutlass S with 350, 4bbl and AC. (Hint: the car was originally a Non-AC and I am converting it to AC - I don't know if I can continue to use the 3-row radiator that I already have). Any clues will be appreciated.
Barry
Old Feb 20, 2025 | 06:56 PM
70Post's Avatar
Barry - I don't have a '72 manual here.
Of course you can continue to use the 3 row rad you have but I don't know EXACTLY what would have been used in the '72 car W/AC. I'm thinking a AC '72 Cutlass likely WOULD NOT HAVE come w/a 2 row rad. I would think the 3 row would have been the "baseline" rad for a '72 350 Cutlass w/AC. That's just what makes sense to me....not based on any facts I have.
If you are trying to get maximum cooling for your combo then stepping up to a 4 row setup would be in order.
FWIW.....if you see references to a "2.00 inch core" then that's the 3 row rad. References to a "2.70 inch core" are a 4 row rad.
There was also a sort of "oddity" that I've seen on some '72 cars (W30)....they had a 3 row rad and the filler side tank was actually from a 4 row rad and the other side tank was a typical 3 row size tank. Thinking that must have been some sort of HD 3 row rad for '72. That setup, I believe, used a 4 row radiator top plate that had a special rubber isolator on the 3 row (D side) tank to make up for the larger 4 row saddle on that side of the top plate.
You should probably move this to some other thread as we are "interfering" with a For Sale ad here.
Old Feb 20, 2025 | 07:01 PM
72OldsCut<'s Avatar
Barry
Roger that. Thanks.
Old Feb 21, 2025 | 02:44 AM
ros6872's Avatar
ros6872
lol--so yes-- this plate is for a 2- or 3 row radiator application which is by far the most common 68-72 Cutlass radiator
Old Mar 20, 2025 | 04:14 AM
ros6872's Avatar
ros6872
Still available
Old Apr 22, 2025 | 04:37 AM
ros6872's Avatar
ros6872
Still available
Old May 22, 2025 | 04:31 AM
ros6872's Avatar
ros6872
Still available
Old Jun 25, 2025 | 02:52 AM
ros6872's Avatar
ros6872
Still available
Old Jul 26, 2025 | 04:37 AM
ros6872's Avatar
ros6872
Still available
Old Aug 28, 2025 | 04:50 AM
ros6872's Avatar
ros6872
Still available
ros6872
Aug 30, 2025 04:40 AM
ros6872
Jan 12, 2025 08:59 AM
ros6872
Oct 22, 2024 04:30 AM
ros6872
May 5, 2023 05:50 PM
ros6872
May 21, 2020 04:26 AM
