Valve Springs
Old Sep 8, 2022 | 08:58 AM
67OAI's Avatar
Old(s)GuysRule
Valve Springs
Two sets of valve springs available, specs following:
Crower inner and outer interference fit, no damper on this type spring, old p/n 68100/68201,
180 @1.700, 335 @1.200, 380 @1.100, coil bind @1.060.
General Kinetics inner and outer w/flat wound damper,
175 @1.700, 360 @1.200, 410 @1.100, coil bind @1.060.
$55.00 plus postage either set.
Old Feb 20, 2023 | 09:23 AM
67OAI's Avatar
Old(s)GuysRule
PRICE REDUCED!
$50.00 plus shipping from 31548, either set.
Old Feb 21, 2023 | 03:28 AM
Jeff Stout's Avatar
Couldn't tell if these were new or not
Old Feb 21, 2023 | 01:13 PM
67OAI's Avatar
Old(s)GuysRule
I didn't say! The numbers posted in the first post were personally verified by me at the time the springs were put away, these are actual tested pressures and not advertised numbers. The General Kinetics (G/K) springs were run several seasons on a mild build "E" block with an off the shelf G/K solid lifter camshaft. Don't remember the specs on the cam but was probably about 310/310 advertised duration and in the low 500s lift. Pontiac 1.5 ratio rockers were used. The Crower springs were used on a later build of the same E block but with a Comp Cams 600 lift custom grind solid lifter camshaft and Harland Sharp 1.6 rockers; had break in time on them and 3 or 4 passes at the track when burned a piston.
NotDads442
May 19, 2021 12:17 PM
Tuffnut
Dec 17, 2018 12:06 PM
1978 Oldsmobile Omega
Feb 8, 2016 05:34 PM
pogo69
Mar 31, 2014 05:01 PM
69ishHoliday
Suspension & Handling
Nov 24, 2013 10:26 PM
