Frant air dam ..little more than 400 miles on it , 83 Olds...$1500
Old May 22, 2021 | 03:54 AM
rocketscientis's Avatar
Front air dam ..little more than 400 miles on it , 83 Olds...$1500
83 front air dam
3 piece front air dam ..currently on a car with 400+ miles
Driverside of an 83 olds front air dam
Center of an 83 olds firenzas front air dam with a little over 400 miles on car..
Passengerside of an 83 olds front air dam
400 mile , 4 speed , and 1 front air dam... \"83 441 olds firenza
1 light rod 4 speed shifter
Considdering donating entire car to museum , or a collector with an adequete roll... Little over 400 miles..
Old May 22, 2021 | 04:18 AM
83 Olds front air dam / associated items
Or perhaps you might prefer the 83 to 84 Hurst Olds front air dam couple those available as well as this T - top roof from a G - body Olds...with both T - tops...no body...
Images are of unit B
roof must B not a dam piece.....Lansing Mi
Lh piece of B unit
Center for B unit
Old May 22, 2021 | 05:39 AM
Any Lh 67 B- body fenders AVAILABLE for trade
Towards what you may require ?
67 has fender extension..66 & 68 do NOT
Old May 26, 2021 | 03:44 PM
DR_DAN's Avatar
II’m confused as to what exactly you are selling
Old May 27, 2021 | 01:51 AM
air dam replacement side pannels
Replacement side dams are available
83 dams were silver Lh as example
84 dams wrre black Rh as example
Image of an original 83 air dam showing the abuse is had taken over the years
Here is the dam schematic
This factory schematic should be of use to quite a few
Old May 27, 2021 | 02:30 AM
If that aint enough to make you flip your lid
This lid & both of its
T - tops are available
I even considdered including the set of 79 H/O rims , but didn't want to go too that extent
BOTH styles of '83 Olds front air dams..& some oddz & ends..
IF , big if ,
things go well l could
be proud new owner of
lightnin rods
An 1108333 from april / may 69 is currently needed I could make due with any 69s '333 ,but there is a man without his correct starter & his needs are particular to spring 69
Recent indications of water pump season , when the water pump bushes are in full bloom , once again the summer savings start with saving your heads, block...gaskets..
Rebuilt Oldsmobile Water pumps for most applications & quite a few dates for sale $225 - $430
Dates & casting #s fluctuate
& always recomend that the cars original unit be rebuilt whenever possible
& loaner pumps that minimise downtime are available as well
Lansing Michigan
Last edited by rocketscientis; May 27, 2021 at 03:11 AM. Reason: Cause,frant word rite upd frant aintent spilled writte & that reallly pisssesss sum of hour moar intellectual tipes
Old May 31, 2022 | 08:23 AM
Djqwest1426's Avatar
Olds hurst
Originally Posted by rocketscientis
Or perhaps you might prefer the 83 to 84 Hurst Olds front air dam couple those available as well as this T - top roof from a G - body Olds...with both T - tops...no body... …….. front air dam available????
Lh piece of B unit
Center for B unit
spgosselin
May 26, 2020 10:09 AM
Mikekuj
Feb 26, 2020 04:03 AM
scrappie
Aug 17, 2019 12:46 PM
Olds24
Mar 26, 2015 07:05 AM
Chuck_66
Jan 22, 2012 03:22 PM
