NIB Eagle Rods CRE673503D
Old Apr 22, 2021 | 09:03 AM
grannys442's Avatar
NIB Eagle Rods (sale pending)
New in box. Purchased from well-respected vendor on this forum. Shipped directly to me from Eagle. Only taken out of box only for photo. $450 with free shipping in cont US. PM me with any questions. Thanks
Old Apr 22, 2021 | 09:17 AM
skyhigh's Avatar
1972 Cutlass Town Sedan
Why did you change your mind on these, made in china?
Old Apr 22, 2021 | 10:17 AM
grannys442's Avatar
I’m building a 400G motor which has a small bore size. Eagle rods physically won’t fit into bore. Lesson learned. At least i caught it early before mounting the pistons and balancing crank.
I ended up rebuilding stock rods. FYI...the outer dimension of the big end is 3.990. My bore is 3.905. I’m not aware of any aftermarket rod (reasonably priced) that will fit into the small bore 400G.
Old Apr 22, 2021 | 12:05 PM
BackInTheGame's Avatar
Just thinking out loud, here, is it known whether your rods will work on the 396021F 455 block? Someone may be able to use the rods in their 455 build.
Old Apr 22, 2021 | 01:06 PM
grannys442's Avatar
Yes sir. These are listed for use in ‘68-76 455 engines.
Old Apr 23, 2021 | 08:23 AM
android 211's Avatar
PM sent
Old Apr 23, 2021 | 10:07 PM
Battenrunner's Avatar
We used these exact rods in our build on our 455, and they are decent after a little proper measurement and correction if necessary and if they are over the maximum bore size, as not all need it. Also, expect that the pin ends will need to be honed to fit your wrist pins. I think they are rated to 900hp.
Old Apr 24, 2021 | 12:03 PM
Bernhard's Avatar
Would it have been possible to clearance the block?
Old Apr 24, 2021 | 12:13 PM
yes, that is also what it takes to run these even in a 455 with a 4.185 bore.... a good amount of clearancing
But some people either don’t understand they have to or don’t want to do that.
Old Apr 24, 2021 | 03:42 PM
grannys442's Avatar
You’re better than me if you can make a notch to allow the rod to fit the bore. The Eagle rods will not fit into a 400G unless it’s bored to at least 4.000 but that’s not possible on all blocks.
Old Apr 24, 2021 | 05:13 PM
I get your struggle, but I would do at least what you said with boring that hole bigger...
those late 400’s are worse than a 305 Chevy!!!
haha.... poke poke
the notching I was speaking of is the bottom of the bores under the litter galley
If I had the money and wanted to keep a 69 442 stock appearing on the block and everything... I would sleeve the block with some big bores so it could open the valve area for good power.
Old Apr 24, 2021 | 07:11 PM
Bernhard's Avatar
How about clearancing the Rods?
Old Apr 24, 2021 | 07:12 PM
Bernhard's Avatar
Thanks for posting.
scrappie
Dec 8, 2024 01:50 PM
oldcutlass
Jun 5, 2022 03:01 PM
oldcutlass
Oct 27, 2019 08:33 PM
j808702
Oct 31, 2016 07:50 PM
WolfmanG
Jan 16, 2012 03:26 PM
