'79 TA with 403 Olds drivetrain - Time to move these goodies along
I've had this car since 1984, and have been through it a few times over the years. Time for it's next chapter in life, and these parts are no longer needed....... many of which have only 500 miles on them. Let me know if you have questions. Help me clean out my garage. Located in Tucson, AZ.
Here we go:
- #6 Casting / 1970 350 Olds heads – 2.00” intake / 1.625” exhaust, Dave Smith street rocker kit DS 4110-H (adjustable),
pushrod guide plates, screw in studs, machined for ½” head bolts (Needed for use on 403 Olds blocks), Mondello SK-245-D spring kit (125lbs seat pressure). I think these measured out to 62.5 cc after machining. Equivalent to a factory W31 head? Springs were matched to a Mondello JM22-25 hydraulic cam which spec'd out at 0.512"/0.523" lift and 274/280 duration with 230/236 duration @ 0.050" lift
$500 or best offer Really want to move these along..... might be able to work with you on shipping as well.
- Kenne-Bell TH400 Switch Pitch transmission, Buick/Olds/Pontiac bolt pattern, fresh rebuild by Sharp’s Transmission in Tucson - 500 miles, switch pitch converter (2000 & 3000 stall), deep cast aluminum pan, adjustable modulator, trans mount & driveshaft yoke, -6AN transmission cooler fittings, speedometer cable
$500 or best offer
- Offenhauser #5822 360 intake manifold, fits 4150 series carb, black crinkle powder coat, welded heat riser, with small block Olds Type II thermostat housing and valley tray https://www.summitracing.com/parts/ofy-5822
$180
- Taylor 9mm plug wires with lengths for small block Olds & R&M billet wire looms (black)
$170 new / $50
- Lokar black floor mount shifter for TH400 (LOK-XFMS6400EB) $245.99 new https://www.summitracing.com/parts/lok-xfms6400eb
Lokar Black rectangular LED boot indicator (LOK-XCINB-1780) $246.99 new
Summit now has these listed at $308.95 https://www.summitracing.com/parts/lok-xcinb-1780
Lokar Kickdown TH400 black stainless steel (LOK-XKD-2400HT) $99.99 new
Lokar Throttle cable kit (LOK-XDP1000HT) $97.99 new
Lokar deluxe top rectangular boot (LOK-X70-BAF3) $35.99 new All of theLokar parts for $350 Over $700 in all of these parts
Joel - I am glad that you liked it. It is almost new! If you don't know who George Montgomery is - look him up ....... He was a famous drag racer from Ohio - and I was proud of the fact that he actually worked on that distributor (or at least one of his employees did!).
All the best.
Jim
