Oldsmobile 468, 455 engine (scam alert)
Old Jul 10, 2016 | 05:12 AM
denzeldunlap's Avatar
It's a 468, 455 .060 over. full performance build. low end is a .060 over block with trw forged pistons, stock reconditioned rods and a N crank turned .010. Rotating assembly has been balanced. Engle 25-28 cam with .523 .544 lift and .238 .244 duration @.050 lift. Double roller billet timing set,melling hi volume pump and hardened drive shaft. Milodon 7 qt pan. Summit hi torque mini starter also included. Up top is Edelbrock aluminum heads, ported and machined for 10.4:1 compression-pump gas friendly.Harland sharp roller rocker arms, comp cams hardened pushrods. Intake is a holley street dominator and on top is a custom tuned 850 cfm quadrajet. Russels fuel line and filter included as well as a liquid filled pressure gauge. HEI distributor,8mm wires and E3 plugs, hi flow aluminum water pump AND ceramic coated hedman headers that fit 70 cutlass-among many others.
This is a lot of engine for the asking price. You supply the fuel pump drop it in and hook a wire to the HEI.It's even painted the correct supercars unlimited olds blue engine paint.
Asking Price is $3,500 freight inclusive.
Old Jul 10, 2016 | 06:35 AM
Magna86's Avatar
Crank drilled for manual?
Old Jul 10, 2016 | 08:30 AM
yes
Old Jul 10, 2016 | 08:35 AM
Location?
Old Jul 10, 2016 | 08:50 AM
Dave Siltman's Avatar
PM sent
Old Jul 11, 2016 | 05:47 PM
Magna86's Avatar
LOCATION? PM sent
Old Jul 11, 2016 | 06:55 PM
I think this is a scam, its the same engine in this post.
https://classicoldsmobile.com/forums...lds-468-a.html
Old Jul 11, 2016 | 07:32 PM
RetroRanger's Avatar
72 Olds CS
its also for sale on ct cl which matches OC link
Old Jul 11, 2016 | 07:42 PM
Edited title, banned user.
Old Jul 11, 2016 | 07:59 PM
Gary M's Avatar
Figured that was too good to be true
Nice catch. Probly saved one of us a good chunk of change. Hate scammers!
Old Jul 11, 2016 | 08:11 PM
Thanks to Dave Siltman who sent me a pm with concerns, it took a little while to figure it out.
Old Jun 7, 2017 | 06:08 PM
71 delta88guy's Avatar
Yes this is my old engine, sold 6 to months ago. And for more than this add.
Old Jun 7, 2017 | 07:02 PM
redoldsman's Avatar
Proud Viet Nam Veteran
The dirtbag had two posts and both were related to this engine. What a scum sucking pig.
real57vetteguy
Apr 22, 2015 10:57 AM
f-85
Jun 6, 2014 05:32 AM
analogkid455
Jun 1, 2014 09:01 AM
6inarow
May 25, 2012 10:04 PM
79MKII
Nov 28, 2011 02:31 PM
