Supercharger manifold for small block
Old Feb 22, 2016 | 11:07 AM
Mrgadget's Avatar
I have a small block supercharger manifold plus the thermostat housing and air cleaner for sale. This is the first one I had that was on the engine for 1 1/2 years, sprung a water leak, got it sealed and decided to have another made with the exhaust crossovers welded up, trued up intake surfaces and the supercharger mounting surface. Switched them recently and had those things taken care of on the original one. Then I decided to make a new thermostat housing, which is needed with this manifold for low clearance, so made an extra one to sell with the original manifold. Will also include the Edelbrock modified air cleaner I used initially. Now I have $750 in purchase,machining,welding and remachining for truing. The thermostat housing and air cleaner, I'm throwing in. Buyer will need to get the Weiand 142 SC kit for a small block Chevy, this gets the belt and proper crank pulley......that will need to be converted to 4 hole pattern form 3 hole(I did this myself with my basic drill press) I can give more info to the purchaser later, then I needed to have .200 taken off the aft end of the pulley for a perfect belt fit. A little long but this is information I think is needed. $500 plus the ride. Last pic is my attempt at cold air intake, works great. Reduced the price
Last edited by Mrgadget; Feb 23, 2016 at 11:11 AM. Reason: Reduced the price to $500. I've listed this on Ebay today
Old Feb 23, 2016 | 11:27 AM
jpc647's Avatar
Wow, the possibilities this could open up for us low comp 350 guys.....
Old Feb 23, 2016 | 12:33 PM
Mrgadget's Avatar
Exactly why I went this way, plus it looks great at the car shows, heh heh.
Old Feb 23, 2016 | 12:43 PM
Joffroi's Avatar
Runner
That looks awesome. To bad I don't have a small block.
Good luck with the sale on it.
Old Feb 24, 2016 | 06:06 AM
jpc647's Avatar
I bet it does. Great work. Unfortunately, there's no way my stock 72 motor would hold up, so this plus the cost of a rebuild puts we way over an LS swap. :/
I'll trade you my small block for your big block, plus some $$$. haha
Old Feb 24, 2016 | 08:25 AM
Mrgadget's Avatar
Yes, cost was certainly a factor, I was lucky enough to score a Weiand 142 on ebay for $1600 and it came with a new Edelbrock 750, so I was in the $2400ish range, but my engine was already built to about 8.5:1, and everything is bolt-on which I like. I run max 5 psi, still holding up so far. If you're running too much psi, put a bigger pulley on the SC.
If it didn't fit under the hood, I was going to go with a big block. My mechanic friend was standing there for quite a while with his sawzall in his hand to cut my nice hood, but I was determined to make it fit if physically possible. Fun project.
Old May 14, 2016 | 06:19 AM
Magna86's Avatar
Is this still available
fast67vellen2o
Sep 10, 2013 08:50 AM
MDchanic
Feb 5, 2012 09:31 AM
jerseyjoe
Jan 7, 2011 10:54 AM
84oldsDelta88
Apr 18, 2009 10:30 PM
citcapp
Jan 31, 2009 04:01 PM
