Original Power Brake Booster Mstr Cylinder Line Clip Setup - restored
EDIT: SOLD - thanks
A nice clean and restored clip/clamp setup for '70-72 Abody's that use a power brake booster. This clamp holds the two steel brake lines that run down to the frame rail from the master cylinder. The clamp is attached to the power booster firewall mounting bracket with the hex screw (included). Some models used a clip instead of this setup so make sure you realize there are two versions.
No pitting, etc....nicely re-phosphated to the original finish along with the mounting screw. Inner rubber insulator pieces wrap around the steel brake lines and are held inside the clamp.....these insulator sleeves are rubber hose that is slit...these are the originals and in real nice condition.
$28 shipped (USPostal) to the lower 48.
PM me for payment options
NOTE: Do you need a Gas Tank Pad for your car?......these parts will easily fit inside the box with my rolled up Gas Tank Pad and won't add anything to the ship cost of the Gas Tank Pad....link to my Gas Tank Pad ad:
https://classicoldsmobile.com/forums...ion-item-7107/
Patton, I have a question for you. Did this clip always have a set of rubber insulators inside? When I restored my clip for my 72 Cutlass, I didn't find that in mine.
Allan - From my experience....yes. Every one of these I've pulled from salvage cars has had the rubber pieces in there. Doesn't make any sense at all not to have them b/c the clamp wouldn't clamp. It doesn't close up tight enough to hold the steel brake lines....they'd just be rattling around inside the clamp. Thus, the factory installed slit hose sections.
You can use any appropriately sized rubber automotive hose and slit them. Not sure of the exact size but it shouldn't be too hard to try a couple sizes and figure it out.
70Post
March 5th, 2015 06:49 AM
Del70
October 14th, 2010 04:55 PM
