Olds 350 High Performance short block
Back in 2004 a friend of mine wanted to build a drag car. He was fresh out of high school and worked at my shop as a clean up kid. He didn't know much about mechanicals, but he seemed eager to learn. I gave him a nice '86 Cutlass with a fresh Turbo 400 and a 12 bolt rear end. I also gave him a 1972 350 engine along with a 330 crank and some Ga BB heads. I showed him what needed to be done to port them but he didn't get too far. I finished the heads for him. I probably have close to 80 hours into them. I bought a bunch of parts for this engine and paid for all the machine work. My friend went into the military and lost interest. He came back from Iraq, got married and had two kids. The car was scrapped but I got the trans and I picked up the engine from the machine shop. I kinda lost track of how much money that I sunk into this thing, so I got out all the receipts and put together this spread sheet. The compression may be too high for pump gas, and I really think it's not going to be very streetable. My car is set up for a BB so I really have no need for this engine. The block is from 1970-1972. The crank and flexplate are original from my 1967 330. I have plenty of core heads if someone wants to purchase a complete running engine that can be arranged. For anyone who is really interested , I can e-mail all the photos taken and blue print data compiled during assembly. I will also throw in a stock oil pan, a split timing cover and an HEI distributor with low miles.
Olds 350 CI Race Engine
1972 350CI engine block core
1967 330 steel crank core
1967 Flex plate
1972 Damper
JE Pistons Custom 2300077 $680.75
Rings J100F84080-5 $100.00
Rod bearings 02-5029 $60.00
Main Bearings MS805P20 $60.00
Rod bushings 02-5029 $40.00
(2) Heavy metal slug 1”X1” $70.00
ARP rod bolt RB-200 $58.00
Freeze plug kit FP-640 $14.00
Race Cam Bearings RCB-499 $69.00
Gasket Set GS-550 $95.00
High Volume Oil Pump SP-754 $69.00
Bolt on pick up PU-3 $35.00
J&S 5 Main Halo $250.00
J&S Main Stud kit $85.00
Custom modern grind cam/ lifters $265.00
Machine Work Performed by LAM Racing Engines
Install rod bushings, Fit/ assemble rods & pistons,
final polish rod beams, Recondition rods with ARP bolts-
includes R&R bolts, machine oil relief grooves in rods,
deck block, piston height + .0001,
Balance rotating assembly, regrind crank
Rods - .020 Mains - .020, install slugs of heavy metal (mill),
Install main studs, mill for main girdle (halo) to 2.175 depth of caps
Dial bore gauge main bearing bores, low limit to middle of spec,
Final wash block and install cam bearings & freeze plugs, check main
bearing clearance and ring end gaps. Total machine shop services - $1311
Final assembly and measurement performed by Dane Lulling of
Mild to Wild Racing $400
total investment- $3825.75
![](http://i291.photobucket.com/albums/ll306/Oldsnut1967/Parts/112-1257_IMG.jpg)
I have all the receipts for this engine. The asking price is $2800. That is a $1000 loss for me, but I really need to sell something to finish my car. This engine is located in SE Wisconsin. I would rather not ship this, but I will supply a cradle and help load. If you need more info you can call me @ 847-740-3283 or PM me here. Thanks for taking the time to read this novel- Dave
1967 Flex plate
1972 Damper
