Need a front seat frame 1970 olds 98 can I use any other gm cars?
It's a bench seat with arm rest in the middle. Power 6 way I think and both backs move forward so people can get in the back as in any 2 door car. Was wondering if anyone knows which specific gm models would work. Thanks
If it's the 6 way and not the 60/40, Hollander interchange says the following tracks will interchange: 1970 Cadillac Fleetwood; 1966 Olds except Starfire; 1967 Olds except Strato; 1968 Olds except 98 convert.; 1969-70 Olds (not 60/40). If the track will interchange and it is the same style seat, probably the seat will also interchange. On the east coast, Metro Used Auto Parts, Chesapeake, VA, is supposed to have a 1968 Delta 88 with a good front seat which should work. It's a bit of a drive for you, but be sure to call first: 1-800-789-8730. There are other possibilities (IN), but even further away from RI. Shipping would be expensive, but perhaps an option. Would rebuilding your frame be an option? Best wishes.
From Ozzie's post it sounds like some of the Toronado's would fit. They were all 2 door cars with the seats that tilt forward to access the back seat. That might broaden your search field.
Are the seat tracks usable with your seat? I've encountered bucket seats that are the same but used different seat adjustment rails and floorboard brackets. I wonder if some bench seats are the same?
John
John
2 door bench seat
I have one from a 69 delta 98. Been asking $200. Should be able to ship fedex probably around $100. It would come in 3 packages. I can be reached at c4004@bellsouth.net. The seeat also has the middle armrest, needs recovering.
kelly @ 318-542-8644
costpenn
Sep 20, 2014 06:21 AM
jensenracing77
Oct 25, 2009 05:22 PM
