BIG N Nodular Crankshaft for 455 This has a bushing installed for manual transmission
PICTURES ADDED
This was removed from a 1970 engine with E heads. Front Counterweight has LARGE LETTER N cast into it.
Crank Shaft for sale. It was ground 10 10 and then run in a jet boat for about 100 Hours. It does show some wear. I did save a couple ROD and MAIN bearings from when I tore the engine down..
I had a machine shop look at it and they told me it should only need a fresh grind. Otherwise looked fine.
You Pick Up Near Minneapolis Price $360. Shipping to lower 48 UPS $100 So Total SHIPPED $460 US POSTAL MONEY ORDER $$ 460 as shipping has gone UP.
Stick and Column Shift Crank for 3 Speed 4 Speeds are hard to find these days. I think this also will work in LETTER G Block 1968 1969 400 Motors
I did also have a flywheel SOLD Thank You
November 14th, 2020 05:53 PM
