1961-65 Oil pan drain plug assembly
Old Aug 17, 2024 | 03:49 PM
v8al's Avatar
Registered Olds Owner
Removed from a rotted 1965 pan. Factory part number 577646.
Used only on Olds V8's from 61 thru 65 except 215's. 61-63 394's and 64-65 330, 400 & 425's.
Includes:
- The "star"/eight point drive drain plug. Good threads. Can be removed via a 1/2" square drive ratchet with no socket.
- Copper washer
- The plate that the drain plug screws into. The plate will need to be "ground flat" to remove a bit of the original welding slag for a nice tight seal but this won't be a problem as there is more than enough material for this.
Everything you need to repair a damaged drain plug, except the welder!
$40 + shipping.
Old Nov 8, 2024 | 09:25 PM
v8al's Avatar
Ttt
Old Mar 20, 2025 | 09:20 AM
v8al's Avatar
ttt
Old Jul 9, 2025 | 04:24 PM
v8al's Avatar
ttt
Old Jan 24, 2026 | 12:16 PM
v8al's Avatar
ttt
rickw30
Sep 6, 2024 07:44 AM
mike 66 toro
Mar 25, 2024 06:46 PM
REO442
Mar 10, 2024 10:39 AM
johnwrolds2018
Jun 13, 2023 06:27 AM
johnwrolds2018
Jan 11, 2022 04:36 PM
