10 BOLT 8.5 CUSTOM NARROWED FOR G-BODY CHASSIS
MEDIA BLASTED AND PAINTED CHASSIS BLACK
NEW 3.73 GEARS YUKON PREMIUM GEARS
NEW MOSER AXLE SHAFTS
NEW YUKON DURA GRIP EATON POSI
NEW BEARINGS AND SEAL THROUGH OUT REAR
NEW UPPER DOUBLE ADJUSTABLE CONTROL ARMS (IT IS WHAT MAKE THE REAR A BOLT IN NO MOD SET-UP)
NEW DRUM BACKING PLATE(THIS REAR WILL USE ALL STOCK 7.5 G-BODY BRAKES)
NEW REAR ALUMINUM EXTRA CAPACITY COVER.
52.25 HOUSING FLANGE TO HOUSING FLANGE (STOCK G-BODY)
57.75 DRUM TO DRUM WIDTH (STOCK G-BODY)
METRIC STUDS 12MM X 1.5 (STOCK 82-88 G-BODY)
5 ON 4.75 WHEEL PATTERN (STOCK G BODY)
I DO NOT BUILD MANY OF THESE REARS ANYMORE...JUST CAN NOT FIND RWD CAR HOUSINGS TO BUILD THEM IN THIS AREA
WE DECIDED TO JUST BUILD THE MOSER 12 BOLT REARS FOR THE G-BODY LESS HASSLE...PULL THE HOUSING FROM THE BOX AND BUILD IT.
1875.00
NEED ZIP CODE TO FIGURE SHIPPING
THANK YOU, JIM
AKRON, OH AREA
