Painting cowl
Old Feb 15, 2019 | 01:20 PM
cdrod's Avatar
Rodney
Painting cowl
I'm getting ready to permanently bolt the body to the frame on my project and want to paint the cowl/firewall with epoxy primer/paint first. Most brands of paint I have looked at say not to spray over lacquer. Is the factory paint in the engine compartment lacquer or enamel? The body is very clean in this area with very little surrust so I was hoping that I wouldn't need to strip to bare metal and could spray over the existing paint. Thanks in advance for your advice!
Rodney
Old Feb 16, 2019 | 05:44 AM
68442's Avatar
The epoxy is a great product to seal off old finishes Etc. to then go to modern paint. One piece of advice, not knowing the actual paints involved, do not put the first coat on heavy as the solvents may be egressive to the lacquer. Light first coat let flash - good to go
Old Feb 16, 2019 | 10:47 AM
cdrod's Avatar
Rodney
68442:
Thanks for the advice. What brands of epoxy primer have you used? I'm thinking of using the Eastwood (Kirker) stuff in the spray cans on for the firewall/cowl area followed up with the Duplicolor DE1624 low gloss black. I'm reading good things about SPI epoxy primer for the rest of the car. Do you have any experience with SPI?
Rodney
Old Feb 16, 2019 | 11:44 AM
My442's Avatar
Get the cowl clean, and then get some Eastwood underhood paint.
Make sure there is overspray and drips, just like GM did!
Old Feb 16, 2019 | 02:51 PM
Be sure to record your firewall stampings before you sand or paint over them.
orsogrigio
21
Dec 13, 2015 02:51 PM
Anti-Ricer
Paint
Sep 18, 2012 12:46 PM
foo
Paint
Jul 2, 2012 05:03 AM
72cutlassolds
Feb 7, 2012 05:12 PM
67 Cutlass
Body work
Apr 22, 2009 05:32 PM
