Hood Stripe Set
Old Jul 28, 2022 | 10:36 AM
Carsick's Avatar
Hood Stripe Set
I'm looking for a decal or stencil set for my 1969 442/ ram air hood). I can't find them but I'm sure they make them.
Old Jul 28, 2022 | 12:29 PM
69HO43's Avatar
Do you mean a 70 ram air style hood on your 69? Or the stock double hump hood on a ram air 69 with scoops under the bumper?
If you need striping for the fiberglass 70 style ram air scooped hood, try here. They seem to have stencils or black/matte black/white striping as well.
1970-72 W-30 & W-31 Oldsmobile paint stencil / stripe kit (stencilsandstripes.com)
You can use the same place as they also sell the wide stripe kit on the hood bumps on the 69 steel hood, either white or black striping or the stencil.
1969 Olds 442 Stripe Kit - Stencils And Stripes Unlimited Inc.
Personally, I wouldn't use the trunk stripe on the 69 kit at all. Those belong on Chevelles.
Old Jul 28, 2022 | 01:11 PM
Trunk stripe kit? They sell a trunk stripe kit??? That explains why every Faux-Four-Two has them now.
Old Jul 28, 2022 | 01:47 PM
Carsick's Avatar
Definitely no trunk stripes for me! I have a 69 with the stock 'flat hood'. Was there a ram air hood that year? Is it a lot to put a '70 hood on with the trim still lining up in front?
​​​​​​Thanks
​​​​​​Maybe I need a stencil kit and I'll paint them on. The car will be white so I think gold stripes would look good. Maybe an 'Olds gold's type shade?
Old Jul 28, 2022 | 01:49 PM
Carsick's Avatar
Old Jul 28, 2022 | 02:03 PM
Originally Posted by Carsick
That's not the flat hood, that's the "double hump" hood that was used on Cutlass S and 442 models. All F85s (except W31s), Supremes, more doors, and wagons got the "uni-hump" flat hood.
Old Jul 28, 2022 | 02:07 PM
Carsick's Avatar
I'm glad I know that now? I'm probably going to sell that and get a snorkel/ram air style...do they make one for the 69? What do double hump hoods go for?
Old Jul 28, 2022 | 02:10 PM
Carsick's Avatar
Glad I know that now! What's this one worth? I want to put a snorkel/ ram air style hood on. Do they make them for 69?
thanks
Old Jul 28, 2022 | 02:12 PM
Good 1969 hoods are actually in demand. People have put the 1970 hood on the 1969 cars. I personally don't think it looks right, but that's a personal taste issue.
Old Jul 28, 2022 | 02:18 PM
Carsick's Avatar
Do you think this would line up? I'll delete the latch and just use the pins....a bit pricey
Old Jul 28, 2022 | 02:25 PM
The pins alone probably won't hold it. Since this is obviously not a factory-correct restoration, consider an all-fiberglass repro. It will be significantly less expensive. VFN Fiberglass and Showcars Bodyparts sell them.
Old Jul 28, 2022 | 04:47 PM
Carsick's Avatar
My biggest concern is the trim on the grill lining up with the hood trim.is it really involved to make the OEM latch work with one? Thanks Joe
Old Jul 28, 2022 | 05:04 PM
Use the 1969 hood tooth and trim. The stock latch either requires the core support to be swapped or modified to match a 70 or the underside of the metal hood frame to be modified to match a 69.
Old Jul 28, 2022 | 07:22 PM
Carsick's Avatar
I'll yank the 'tooth' on my current hood. The front clip is off right now. Is it easier to swap in a new core support or mod the one I have?
Old Apr 20, 2024 | 11:34 AM
Chatt's Avatar
Lots of stripes
Old Apr 20, 2024 | 01:06 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
https://phoenixgraphix.com/gm/1969oldsw42.php
PHOENIX GRAPHIX has many Olds strips. Which ever hood you decide to use.
Personally Id rather see the W30,31,32 scoops under the bumper on a 68 69.
gvermillion
Jul 11, 2021 06:47 AM
zekecut70
Paint
Mar 25, 2021 08:10 PM
viking blue
Sep 19, 2018 12:50 PM
w30hurstolds
Hurst/Olds
Mar 23, 2014 09:39 PM
trucker442
Jul 24, 2012 06:42 AM
