71 Bittersweet Olds owners-need your help!!!!!
Old Apr 11, 2017 | 08:37 AM
johnbumb@charter.net's Avatar
I am undergoing a frame off on my 71 Bittersweet colored 442. I was just told by my painter that PPG discontinued that color. What would you suggest? I want to keep the car as close to factory as possible. Thanks in advance for your help.
Old Apr 11, 2017 | 09:55 AM
vette442's Avatar
That shouldn't be a show stopper. PPG wasn't the original supplier, Dupont probably was. Get a paint sample from up inside your trunk or behind your door panels or another hidden place where it isn't sun-faded and have it custom matched by a paint supplier if necessary. You can try Dupont, Sikkens and other brands as well that may have the correct blend. Good luck!
Terry
Old Apr 11, 2017 | 10:21 AM
Auto paints are mixed from pigments, so you can't really "discontinue" a color. If anything, PPG has deleted or never developed a conversion from the original lacquer mix to modern materials. Other vendors can mix this color, or you can bring a sample of the old paint as noted and have it matched.
This page has the cross references for other paint manufacturers. The original GM color code was WA4140.
Old Apr 11, 2017 | 01:53 PM
Oldsmaniac's Avatar
You may want to try here.
http://www.tcpglobal.com/Automotive-...toration-Shop/
Old Apr 11, 2017 | 02:55 PM
VC455's Avatar
Barely Registered
My painter did as Terry said--he took in a wind deflector with a peeling second coat and matched the color to the factory paint underneath. We recently compared the color he got with a SSIII spare wheel painted with the original color. The two items had indistinguishable color difference.
In other words, with a little work, the color will turn out great!
Keener
Jan 15, 2017 09:52 PM
Lady72nRob71
Jun 11, 2014 06:26 PM
evans_78
Mar 20, 2013 12:46 PM
BIGJERR
Aug 16, 2010 07:34 PM
