Air Flow/Cooling/A/C Question
Old Dec 11, 2009 | 05:39 PM
redvettemike's Avatar
I recently restored a nice '71 442. It is an a/c car. I had the radiator rodded and put on a new water pump, thermostat, etc. I wanted to make sure that it ran cool enough on hot southern summer days. It seems to do fine. Those cars, back in the day, had some rubber seals that went down in the radiator support. When you pushed the radiator down in the support these seals keep air from flowing around the radiator. There are other seals on the corner of the radiator, on the top and also on the bottom. All are meant to keep air flowing across the radiator. I failed to put the seals down in the radiator support. Do you folks think that would have much affect? Are they considered essential, especially when running a stock a/c on a hot day? (The engine is stock.) I am going on the Hot Rod Power Tour in June and I need no cooling issues. Thanks.
Old Dec 11, 2009 | 06:02 PM
ozoneblue's Avatar
If you have any concerns install a external cooling fan & if you are using R 134@ it runs at a higher head pressure
Old Dec 11, 2009 | 07:06 PM
Lady72nRob71's Avatar
The rubber flaps are easy to install anytime. There are two on the top and one big one at the bottom of the bumper. This is more important to ram large amounts of air through the radiator at cruise.
The side seals are good to have, but leaving them out will not cause overheating (the gaps are too small).
Make sure your shroud is there and the fan clutch works (roaring noise upon cold startup, which lasts a few minutes, and when idling hot).
Replace radiator cap if it is old.
If is runs okay now, you should be fine.
russellprocissi
Apr 16, 2014 01:14 PM
Lee_A
Aug 15, 2013 12:32 PM
chip-powell
Jul 7, 2013 01:31 PM
AZ442
Jul 16, 2010 05:34 AM
schapman33
Aurora
Dec 8, 2008 07:49 AM
