Not enough Fuel lines .
Old Nov 2, 2023 | 02:38 AM
Kapos79kutlass's Avatar
Hows it going family , i got a short question . Ok olds 1973 455 into 1979 cutlass , gas tank has two lines coming out , one down passenger side ( to fuel pump ? ) and the other down driver side ( return line to tank ? ) fuel pump 3 lines outer is fuel in , small middle one is fuel return and inner threaded line is to carb. ?
Old Nov 2, 2023 | 06:17 AM
oddball's Avatar
You can get a different pump with only two fittings - inlet and out to the carb. Just look around other Olds applications. Some cars were set up with a return line to address vapor lock.
The smaller line on your tank should go to a vapor/charcoal canister. Maybe? I'm not familiar with the emission controls on the '79.
Old Nov 2, 2023 | 06:33 AM
Your 1979 Cutlass did not use fuel return. The pipe on the passenger side is the feed line from the tank to the pump. The pipe on the driver's side is the vent line to the charcoal canister. You can either replace the pump with one that doesn't have the fuel return line or you can cap that port on the pump you have. It won't matter either way.
Old Nov 2, 2023 | 02:14 PM
so capping the middle one want flood the carb or blow the line ?
Old Nov 2, 2023 | 04:06 PM
I wouldn't have told you to do it if there were side effects.
Old Nov 2, 2023 | 11:24 PM
Thanks .
mdd71
Aug 15, 2024 03:54 PM
jensenracing77
Feb 27, 2016 06:07 PM
69 holiday
Jan 9, 2014 09:30 AM
btrbill
Feb 20, 2012 07:23 AM
Charlie_brown
Sep 29, 2009 04:01 PM
