1966 98 Steering Repair
Old Jan 11, 2020 | 06:36 PM
bigoldscruiser's Avatar
2 '66 98's
Does anyone know the exact procedure for getting the fluid back into the power steering system after complete disassembly? I had it a few years back after I had the pump and box rebuilt by Chip's in St Louis but I no longer have it. I failed to follow the procedure exactly the first time and caused the check valve in the pump to lock up, which had to go back to Chip's for correction. I don't want to have a similar problem again. Thanks, Bruce
Old Jan 11, 2020 | 07:23 PM
I basically jack the car up so the front wheels are off the ground a bit. Start the engine after making sure the pump is full and turn the steering lock to lock a few times.
Old Jan 12, 2020 | 06:56 AM
^^^THIS. And the "exact procedure" is in the Chassis Service Manual in the Steering section and it looks a lot like what Eric wrote. Basically you turn the wheels full lock to full lock with no weight on the front end until the noise stops.
AJFink
Sep 3, 2019 10:48 AM
yellowone
May 8, 2019 09:25 AM
My2nd 69 442
Apr 16, 2018 07:17 PM
brown7373
May 20, 2015 02:46 PM
Stevec
Suspension & Handling
Jul 15, 2011 02:42 PM
