Odd thing inside quadrajet?
Old Feb 7, 2019 | 10:51 AM
Mikey_mick's Avatar
I saw this inside the ‘73 350 quadrajet I am taking apart. Is this an odd thing? The other carbs I took apart didn’t look like this. I though at first that it was cracked but I now think that it was put there on purpose.
Old Feb 7, 2019 | 12:27 PM
OLDSter Ralph's Avatar
What are you referring to ?
Old Feb 7, 2019 | 12:43 PM
Mikey_mick's Avatar
almost looks like somebody put a 1/2” drill bit in here and drilled it out.
Old Feb 7, 2019 | 02:08 PM
D. Yaros's Avatar
It sure does not look factory.
Old Feb 7, 2019 | 05:19 PM
I am far from any Q-Jet expert (although I've rebuilt several) and I know that area is called the booster rings. The only reason I'm responding is because I read in Ruggles' Q-Jet book about modifying booster rings and it was then I did a tiny bit of research on why someone would modify booster rings. So, I just looked in Ruggles' book, he talks about modifying the booster rings but I don't see anything resembling your picture.
I did have a look (Google Search) and Ruggles talks about...in 1971 Pontiac used a special version of the Quadrajet lacking the outer booster rings... They were a special casting and lasted one year.
http://In 1971 Pontiac used a specia... booster rings
Maybe you found one.
Old Feb 8, 2019 | 05:49 AM
Mikey_mick's Avatar
I looked up that Pontiac one you are referring to. That one looks way different. I wish I did have one though because apparently they’re worth lots of money.
Thanks for the info though.
Old Feb 8, 2019 | 10:54 AM
mrolds69's Avatar
My guess is that somebody ruthlessly jammed a screwdriver into it to hold the choke plate open because it was flooded or wouldn't start. That broke the piece off.
1bad442
Aug 2, 2021 10:05 AM
allyolds68
Jan 14, 2019 10:45 AM
allyolds68
Jan 13, 2019 04:07 PM
72455
Dec 25, 2018 01:22 PM
tdhill01
Oct 9, 2018 11:00 AM
