Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
Engine Stalls on Hard Braking
Old Jul 3, 2015 | 08:04 PM
starfire's Avatar
My 1978 Starfire with the Chevy 305 (from the factory), 2 bbl 2GC carb, and 4-speed manual transmission. Electronic ignition from the factory. The car is as it was from the factory.
When the car is cold everything is fine. When it warms up, and I come to a hard stop, it dies (yes I have the clutch pedal depressed or am in neutral). Starts up again immediately. I unplugged the brake booster and capped the line from the carb. No difference, so it doesn't seem to be related to the brake booster vacuum. If I slow down very slowly and come to a gentle stop, it stays at idle no problem. I replaced all of the vacuum lines last fall, there are none missing. I replaced the EGR valve last fall also. I have been noticing a rough idle when warm lately.
Any ideas on where to start with this?
Old Jul 4, 2015 | 05:44 AM
rustyroger's Avatar
'87 Delta 88 Royale
What is your idle speed?. Could be the engine needs a tune up, possibly you have a vacuum leak somewhere.
A proper tune up should reveal any underlying problems, if you need new intake gaskets or whatever you would need a tune up after the repair work anyway.
Roger.
Old Jul 4, 2015 | 05:46 AM
What are your tune up settings?
Old Jul 4, 2015 | 07:10 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
There could be crud in the carb? It moves around when your stoppin hard.
Old Jul 4, 2015 | 08:47 AM
starfire's Avatar
Professionally rebuilt carb. Tuned up last fall to all factory specs. Low idle speed is 600, per spec. All new vacuum lines. I will test for vacuum leak with carb cleaner later today. If that is negative I guess I'll run through the tune up again.
Old Jul 4, 2015 | 06:42 PM
starfire's Avatar
OK, checked for vacuum leaks and found none. Checked tune-up and everything is as it should be. 4* @ 600 rpm with distributor vacuum line plugged and trans in neutral. Low idle set to 600 rpm with EGR vacuum and purge lines plugged.
Took it out for a test drive tonight, took the same route last night and could not get it to die when I braked hard. Hmmmm. Idle still seems rough though.
Old Jul 4, 2015 | 07:48 PM
Are the a/f mixture plugs still in the carb? Have you hooked a vacuum gauge to it?
I noticed that the later year 305's the timing is set to 6 and the idle was bumped to 700.
TheBirds
Oct 13, 2013 07:44 AM
plee3 64Olds
Aug 2, 2011 02:25 PM
cluelesscutlass
Jul 31, 2011 10:32 AM
oldsonharmont
May 28, 2011 07:09 AM
<sparkmn13>
Dec 15, 2006 05:51 PM
