Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
Need help finding a part!!
Old September 5th, 2014, 01:38 PM
mmmm, starfires
justintiime's Avatar
1965 Starfire, 425ci, th400 trans, air conditioning
I need the metal fuel line that goes from the fuel pump, to the carb!
Fusicks = No
Inline Tube = No
Classic Tube = No
I can try to replicate mine, but that requires buying another tool that I will use once in my life and that seems like a waste
justintiime is offline
Old September 5th, 2014, 01:56 PM
jaunty75's Avatar
Maybe you've thought of this, but why wouldn't one for a '66 or '67 full-size Olds work? It's the same engine, right? I see that inline tube, as you say, does not show this line for the '65 full-size Oldsmobiles, but they do for '66 and '67. At least for the 425 with 2-bbl carb. Interesting that they don't show one for a 425 with a 4-bbl. I wonder why.
I bought one of these myself back in 2009 when I put one in on my '67 Delta 88 with a 425 2-bbl. Part number OCC6681 on this page:
http://inlinetube.com/Preformed%20Li.../OO-CAT-05.htm
If you'd like, I can take few detailed photos of it and post them here or email them to you so you can see what it looks like and compare it to what you have. Maybe it's not an exact fit to what you need but could be bent a bit to fit or a new fitting put on one end or something like that.
jaunty75 is offline
Old September 5th, 2014, 02:05 PM
jaunty75's Avatar
In investigating a little further, it appears that '65 was different from '66 and '67 in terms of the carburetor as '65 was the last year that Olds used the 4GC. So the problem you're having is probably due to the difference in carbs between the '65's and the '66's and later. That's assuming you have a 4-bbl carb.
jaunty75 is offline
Old September 5th, 2014, 03:03 PM
mmmm, starfires
I do. 4GC
Old September 5th, 2014, 03:13 PM
Jetstarjim's Avatar
Maybe check and see if Autozone has a bender in their "loan-a-tool" program.
Jetstarjim is offline
Old September 5th, 2014, 03:34 PM
Beer Connoisseur
70cutty's Avatar
You can get a bender for a few bucks on ebay. It will come in handy when your brake lines start leaking.
70cutty is offline
Old September 5th, 2014, 08:04 PM
67 Cutlass Freak's Avatar
If you want to send me your old line, I will bend up a new one for you. I will supply the line and fittings N/C, you just pay for shipping both ways. I can make it in steel, copper, or aluminum. Just PM me and I will send you my address.
67 Cutlass Freak is offline
Old September 6th, 2014, 05:22 AM
The better question is, why wouldn't a fuel line from a 1965 442 work? The 400 and 425 are externally identical and both came with the 4GC carb in 1965. ILT P/N OCC6508 is for a 1965 400 motor with 4bbl.
joe_padavano is offline
Old September 6th, 2014, 03:03 PM
mmmm, starfires
What is ilt?
Old September 6th, 2014, 03:08 PM
Originally Posted by justintiime
What is ilt?
Inline Tube
Old September 10th, 2014, 04:37 AM
mmmm, starfires
they didn't have it either. BUT I had a good idea. My convertible is at the shop for maintenance now. I asked my buddy to pull the fuel line off the car and copy it. Bam...metal fuel line for my blue car
Old September 10th, 2014, 05:35 AM
Oldsdruid
rocketraider's Avatar
Have him make up a few more... you can't be the only one needing a 1965 big car fuel line.
I remember what it was like finding a good metal line for my 64, and at that time nobody repopped those either.
rocketraider is online now
Old September 10th, 2014, 05:57 PM
If this is a response to my previous post, are you saying that ILC doesn't carry part number OCC6508, which is shown in their catalog? Again, this is a 3/8" line for a 1965 442, which should be the same line for a 1965 full size.
Old September 10th, 2014, 08:30 PM
mmmm, starfires
rocketraider, thats a great idea!
joe, they had a guy there that says he has a 65 starfire, and the bends on the 442 line were not correct and it was hitting some bracket??
rhett838
Body work
April 16th, 2014 09:04 PM
Alvin
January 23rd, 2011 11:14 AM
the_onlyclw
March 8th, 2007 03:04 PM
Razorback1974
January 20th, 2007 07:20 AM
alan69delta88
August 12th, 2006 09:01 AM
Quick Reply: Need help finding a part!!
