Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
305/350 headers on a 307 will it work
Old Apr 8, 2020 | 06:04 AM
Skribble93's Avatar
Hi all just wondering will the headers for a chevy 305/350 fit a 307? I mean visually from looking olds has the peak in the center and less bolts but most headers i see that are not insane on price that "fit 85 307" on sites are sbc flange and i really don't want to take my manifolds off to see if the heads are indeed able to accept them being that leads to new bolts and the task of possibly removing ones that break just to find out otherwise. I have the time currently to do it ( Covid-19 travel restrictions and shutdown job) but don't want to have my car in pieces to find out olds headers only.
Old Apr 8, 2020 | 06:51 AM
redoldsman's Avatar
Proud Viet Nam Veteran
No, they will not bolt to the Olds heads. Sorry.
Old Apr 8, 2020 | 08:22 AM
Chevy exhaust flange:
Oldsmobile exhaust flange:
Old Apr 8, 2020 | 08:32 AM
Skribble93's Avatar
Yea i knew the difference even though for some reason my manifolds have 2 holes between the center and end ports but only are bolted next to the center. Just get thrown off by summit giving me a part number to headers that should fit but they have a chevy flange. Long tube's are cheap enough for olds just have clearance issues being the 307 was not meant to be in the Omega manifolds clear fine but headers would be tight and require some fabrication and moving pipes then welding back together to clear the starter and control arms properly so nothing hits and it won't cook the starter. Just needed to be sure olds didn't double pattern heads or anything. Thanks for the input guys much appreciated.
Old Apr 8, 2020 | 08:36 AM
Summit, Jegs, et al pretty much list EVERY Chevy part as fitting an Olds, since the Chevy-centric world assumes every non-Chevy has had an SBC swapped into it.
ao177snipe
Apr 29, 2015 07:09 AM
djhoth
Jan 4, 2012 12:04 PM
johnspd22
Dec 29, 2009 07:36 PM
jabba
Jan 25, 2009 07:27 PM
Fear Reborn
Sep 14, 2007 07:26 PM
