Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
Omega-should I?
Old Aug 25, 2010 | 04:36 PM
radioburningchrome's Avatar
Omega-should I?
Came across what I believe to be a 77 Omega, while looking for parts to my 65 Delta. Owner told me it belonged to a kid who tried to do a manual conversion then stopped. Block is there, no intake, etc. I talked him down to $750 if he pulls the "350". My research tells me only the following were available:231,260,305.
Is this worthwhile?
What engines would fit?
Old Aug 25, 2010 | 04:42 PM
More pics.
Old Aug 25, 2010 | 06:02 PM
Anything made by GM, given the right mounts. The front subframe and suspension shares quite a bit with the second gen F-body. Note that there's already someone on this site looking for 403 T/A engine brackets to swap a 455 into one of these. I would also check the availability of patch panels before committing to buy.
Old Aug 26, 2010 | 07:07 PM
hamm36's Avatar
I talked him down to $750 if he pulls the "350". Is this worthwhile?
Looks like no driver side back window, extensive rust on quarters??? They would have to pay me to take it, with no motor, and who only know what else the kid did to the car.
That would be my take, use the money to fix what you have.
Old Aug 26, 2010 | 07:43 PM
rocketraider's Avatar
Oldsdruid
Those years, except for grille/nose and taillights, whatever fits a Nova of same bodystyle fits the other X-body cars. So a quarter glass and sheetmetal shouldn't be all that hateful to find. Interior might prove to be the problem. WIth the right mounts, an Olds 350 or 403 would be a natural for that car.
Little finance car lot here has a 74 Nova coupe that is in really decent condition except interior- the cloth seats are dryrotted and trashed. It's a 6-cylinder automatic and it's that light metallic green GM slathered on everything in the early 70s. I think the guy wants a bit much for it, but the thought has crossed my mind to save it, WITH THE 6-CYLINDER. I know what he's angling for, is some yahoo sees a Nova and wants to stick the ubiquitous and boring GM 350 crate in it along with a set of Chevy rally wheels.
And I'd keep it 6-powered with the wheelcovers and whitewalls just to **** off the Chevy crowd around here.
Old Aug 27, 2010 | 05:30 PM
toro68's Avatar
Thumbs up
I would too!
Old Aug 27, 2010 | 05:41 PM
Thanks for the good advice.
Old Aug 27, 2010 | 05:42 PM
The voice of reason!
Old Aug 27, 2010 | 05:45 PM
I agree with rocketraider and toro68. Keeping a six cylinder would be a big change from the norm, and much cheaper!
Old Aug 27, 2010 | 06:02 PM
nova7579's Avatar
They make quarter skins for the Nova which would work for the lower portion. The only difference from the Nova quarter is around the taillight. Front fenders are the same as all the X-body 75-79 cars. The interior plastic pieces are supposed to be available from Classic Industries.
Old Dec 29, 2010 | 09:18 AM
red rag top's Avatar
Did you ever wind up buying this car? I am searching for parts for my Omega and would like to know where this one is.
Old Jan 18, 2011 | 08:49 AM
Never purchased the car. Too many things wrong.
What parts are you looking for?
Here is another Omega (whats left) in another yard.
Old Feb 25, 2011 | 07:26 AM
Dr-O's Avatar
Big Block slids right in!
Most panels are the same as any other x-bodies. I have 1 Nova fender and both quarter panels from a Nova. My subframe came from a 75 Nova because it had Manual steering and manual disc brakes. The 455 slid right in and I welded the motor mount pads to the frame. (knowing there would be nothing but a 455 in the engine bay for me anyway) Just dropped the trany mount in the crossmember and welded the front mount pads to the frame! Done!!!!!!!!!!!! 68-72 Cutlass headers bolt right in and clear fine! 1 7/8" primary tube headers worked fine on the street with 3" exhaust out the back. I like the 73-74 Omega but didn't care for rear steer I prefer the front steer for header clearance and handling.
QS442
Nov 9, 2013 06:11 AM
Redog
Sep 5, 2008 05:31 AM
Redog
Nov 16, 2007 05:52 PM
<Don P.>
Jan 8, 2005 10:46 AM
