Inside heater control
I have a 1963 Starfire that only the off button will catch. The rest of the buttons go in but will not stay in. If anyone could help me with this I would greatly appreciate it. Thanks in advance
How hard are the buttons to push?
My guess is the control head is dusty and gunked up after 50 years. Try taking it out of the dash and spraying a little WD40 or similar in the controls. Once you have it out of the dash you'll see how the latch bar and rotary selector valve work.
Try to do it without removing the vacuum lines from the control head. If you have to do that, mark each one carefully as to where it goes.
Thanks for the info and I will do what you recommended. Also when I push the buttons nothing works not even the blower. I know it's run by vacuum and I have checked to make sure I have vacuum on it. I can move the lever on the outside of the blower housing and the blower will come on. It's like the control inside is not letting vacuum through to control any of the diaphragms. I am new to this setup so any help is greatly appreciated.
jensenracing77
March 19th, 2014 04:08 PM
