Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
65 starfire
Old Jul 11, 2011 | 03:32 PM
willj's Avatar
65 starfire
just out of curiousity , can ayone tell me what series the 65 starfire falls under, i want to make sure so i get the right torque specs, thanks very much to all, this site is such a great help, will.
Old Jul 11, 2011 | 03:51 PM
rocketraider's Avatar
Oldsdruid
The Starfire is considered a B-body car, series 6600 in 1965.
Which torque specs do you need Will?
Old Jul 11, 2011 | 05:45 PM
willj's Avatar
torque specs
thank you for the info on the series, basicley i need the torque specs for the front a frams , my manual is in very hard shape , would appreciate it , thanks again ,will.
Old Jul 12, 2011 | 06:59 AM
copper128's Avatar
Lt. Buzzkill (ret.)
upper control arm pivot shaft nuts: 55 ft/lb with car on the ground
pivot shaft-to-frame nuts: 105 ft/lb
ball joint stud nut: upper - 40 ft/lb (minimum), lower - 70 ft/lb (min)
lower control arm pivot bolts: 75 ft/lb with car on the ground
Old Jul 12, 2011 | 07:16 AM
willj's Avatar
thanks
for the torque info, really helpfull.will.
1962oldsguy
May 19, 2019 08:08 PM
Kyle's 77 Cutlass
Jan 1, 2014 09:06 AM
Oldssupreme
Feb 3, 2013 06:26 AM
Oldssupreme
Feb 3, 2013 06:24 AM
slhandpaz
Oct 24, 2005 05:17 PM
